I-90 Minneapolis to Spokane
Discussion in 'Questions From New Drivers' started by windsmith, Feb 27, 2013.
Page 1 of 5
Other than I-90 isn't in Minneapolis.
truck stops are on the ID side of Spokane, Post Falls. Except for the Prtro on the far west side.
Snow, hills, chains, cold weather.
Who knows the sun may shine even.Logan76 Thanks this. -
Yeah, that's what I get for trying to post while doing 3 other things.. I-94 would be the correct road hehehe
You'll want to take 94 to billings, then 90.
You'll have a series of passes to go over from bozeman to cour d'Alene.
Get fuel in fargo and again in laurel mt just past the scale. Nice little hole in the wall ts.
And have your ducks in a row BEFORE you cross the scale in laurel.
There is a flyin hook in spokane. Good food, not much parking. -
Banana bread French toast at the cafe on the edge of the parking lot of the Town Pump/Pilot truck stop outside Missoula. Exit 109
so good. -
4th of july pass is a fun one. Been a long time since I was up there tho. U will do fine tho WS. Be safe out there. Enjoy it.
From minneapolis, I-94 to I-90 in Montana. You have 5 passes, Bozeman, Homestake, Lookout, 4th of July and one more in Montana. Western ND watch out for buffalo. Nice easy route except for the passes which aren't really that bad
Got chains?
If you happen to run through more of ID than the little bit you will, make sure your logs are really tight. They time you between coops.windsmith Thanks this.
Page 1 of 5
