The route is from Des Moines IA to Salt Lake City UT. Planning on leaving Thursday early morning. Driving a 16 ft box truck and auto transport on a trailer. I understand that I-80 WY is the biggest issue. Should I go south instead? Will the current wildfires in the panhandle of Texas possibly affect the southern route? Need suggestions on routes asap please.
I-80 Wyoming in a Box Truck
Discussion in 'Questions To Truckers From The General Public' started by User6831, Feb 27, 2024.
Are you leaving soon? Looks windy in Wyoming over the rest of the week. Colorado and Utah look good for the next three days at least. I-80/I-76/I-70/US-6/I-15 is the way I would go.
Blagoje Thanks this. -
Well, I-70 will take you though the heart of the Rockies, with a lot of curves, steep mountains, and not a lot of affordable places to stop. Nice to see in your car, not a place for a rookie driver with an overloaded 6-wheeler to drive. Especially if it snows. You'll also have to get through Denver, first.
The biggest issue with WY is wind. Stop at Little America when you go past it, and be careful crossing the Wasatch range, especially if it snows. You should limit downhill speeds to about 40-45 mph, gearing-down when needed.Blagoje Thanks this. -
Keep in mind, not only will your rig be heavily loaded so that climbing a steep 6% grade will likely slow you down to about 35 mph, but you are also gaining elevation. At 10,000 ft, you will have lost at least 1/3 of your power just due to the altitude. You may end up climbing at as slow as 20mph, revving at max RPM, possibly overheating your motor. Then you have the downhill. I wouldn't even CONSIDER driving such a combination unless the car trailer also has trailer brakes and a stability coupler. And, trust me, you will NEED to descend those mountains at a slow speed as well, lest you smoke your brakes and end up an out-of-control rocket heading downhill at 80 mph into the nearest escape ramp. I grew up in Boulder, and I have 1 million + miles driving experience on large trucks. I would choose the Wyoming route 100%, without exception for your trip.
Also, keep in mind that there are big wildfires in the Texas panhandle right now. Also, an extra 1000 miles will set you back at least another $500. I 80 goes STRAGHT to SLC. Just deal with the snow, it's the safest route. If you have to wait out a closed highway for a day, you'll still arrive in SLC before you would going south, or breaking down/crashing in the mountains.User6831 Thanks this. -
I doubt the OP will ever post here again, but if he got past Rawlins, he's good all the way to SLC. Laramie to Rawlins, however, has a high-profile vehicle ban on both I80 and US30, though, due to winds. Still, you could just rest-up in Laramie, maybe even overnight it, and they'd still be better off than having to go through Albuquerque...
Colorado on I70 is wet with icy spots from Georgetown to Vail, with slowdowns only on the uphill climbs to the steepest passes. -
Cat sdp Thanks this.
