I’ve got a nail in my drive tire and a hot load.
Discussion in 'Experienced Truckers' Advice' started by Midnightrider909, Mar 5, 2020.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    That’s the situation and I have 1400 miles to go. The head of the nail is in the center of the tread and not leaking air at the moment. I don’t have time to stop and get this fixed until after I deliver tomorrow. What are the chances it won’t pose a problem for the next 1500 miles or so?
  3. Opus
    135,662
    dude.....you could go to just about any truckstop and have them plug it in 30 minutes or less.
    On the other hand, you could stop every 200-300 miles and put air in it
  4. Numb
    Numb Crusty Curmudgeon
    4,477
    10,891
    Jan 30, 2012
    Charlotte, N.Carolina
    good chance it could start leaking down.
    or not.
    I'd pull it and see if it went through. use widow cleaner to check for bubbles.
  5. ed4207
    ed4207 Bobtail Member
    31
    81
    Apr 22, 2006
    Spray water or glass cleaner if it's not leaking run it. Just check when ever you stop. Have it fixed after you deliver.
  6. homeskillet
    homeskillet Road Train Member
    6,720
    53,417
    Jun 1, 2013
    Dayton, OH
    Did you soap check to see if it was leaking air, or just listen?
    Could be a short nail that hasn't fully penetrated the tread, or a long spike that is just gonna cause a bigger hole through the constant pounding.
    If the tire DOES have a slow leak, your chances of a blowout dramatically increase, and a blowout will DEFINITELY make you late.
    I know what I'd do, but you do you.
    Good luck.
    tscottme Thanks this.
  7. Dennixx
    Dennixx Road Train Member
    4,624
    15,005
    Feb 13, 2010
    twin cities
    tinytim, not4hire, tscottme and 4 others Thank this.
  8. Wasted Thyme
    7,729
    38,311
    Jan 27, 2020
    GOAT watching
    so find a truck stop on your route that can fix the tire during either your 10hr or your 30min break. It's called trip planning and calling ahead. Then you're gonna be stopped at that time anyways. you're risking it blowing and being in a ditch and not delivering your load at all. Why risk it?
    tinytim, not4hire, beastr123 and 5 others Thank this.
  9. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    It passed the Windex test.
  10. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Dennixx Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,645
    13,372
    Jul 6, 2009
    Air hose and plug kit.
    2 handy items to have.
