Hydraulic platform trailers
Discussion in 'Heavy Haul Trucking Forum' started by m16ty, Jan 23, 2016.
  1. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    New guy here but not new to heavy hauling.
    I was wondering if anybody has had any dealings with hydralic platform trailers like a Goldhofer? We rutinely move loads 250,000lb+. Usually it's only a couple of miles from the nearest rail siding to the delivery point.
    I'm looking at maybe 10-12 lines.
  3. nate980
    nate980 Road Train Member
    2,020
    5,225
    Dec 23, 2010
    Langley BC
    My work has one and the guy that runs it says he loves it. Pretty manoeuvrable and pretty fancy I must say.
  4. m16ty
    2,265
    4,942
    Jan 22, 2016
    We've been hiring out the loads and have been paying out a boatload of money for it. We also have been running into some pretty tight spots at the delivery point where I think the platform trailer will really pay off.
    The main problem is I've never really been around them much. I'd assume they would be pretty maintenance intensive. With 10 lines your talking about 80 tires and 40 sets of brakes, not to mention all other stuff required to make it work (hydraulics, electronics, steering, etc).
    I've already got a truck that I think will work for a prime mover. Mack RD822, E9 500hp v8 mack engine, 12 speed trans, 20K front, 65K rears, and double frame. I've also got a 4 speed Spicer auxiliary lying in the floor that I'm thinking of putting between the trans and the rears.
  5. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Well if you do get one, this seems to be the easiest way to check and fix all that stuff underneath.
    Our 6 axle beam dollies are hydraulic steer and we have been using them for 5 years now. This year was the first year having trouble with the steering on one trailer the biggest issue that we have is with the tires wearing. We use them 5-12 times per year so there is really not that much maintenance on them. I know that it is not the same thing you are talking about but it is the biggest we use.
    johndeere4020 Thanks this.
  6. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,889
    May 1, 2013
    In purgatory
    They are quite maintenance intensive trailers. They are awesome at what they do, but with the amount of valves and moving parts on them they should be.
    @nate980 I think he's asking about the Mammoet/Entrec/Sarens style platforms, not the Goldhoffer/Sceurle's you guys and us have.
    nate980 Thanks this.
  7. m16ty
    2,265
    4,942
    Jan 22, 2016
    I'm currently looking at a 10 line Nicolas. They seem to be quite a but cheaper than the Goldhofer but I do understand they they aren't built quite as heavy as the Goldhofer.
    Another thing I'm thinking about is a neck. It doesn't make sense to me to add a bunch of counterweight to the prime mover ( increasing the gross) with a towbar when you can have a neck that will take part of the load and transfer it to the prime mover. Most you see use the towbar though, why is that?
    Cnsper, I've seen those pics on the net and do have a little concern about the stability of the system.
  8. Heavy Hammer
    1,184
    5,889
    May 1, 2013
    In purgatory
    A platform doesn't transfer weight like a lowboy to make a gooseneck work.
    I don't know a lot about platforms, but I know enough that if this is your line of thinking I think you need to do some more research before you step off the cliff.
    This is not meant to be insulting, but I don't believe any really experienced platform guys frequent forums. At that level, knowledge becomes almost trade secret. That's why they get the really big bucks.
  9. m16ty
    2,265
    4,942
    Jan 22, 2016
    Yes, in a way they do. The neck is hydraulic and it is tied into the hydraulic suspension. It will maintain a certain weight on the 5th wheel, regardless of suspension height or ground conditions. It also controls the steering somehow. Mind you I've never actually seen a neck in person but this is what the manufacturers tell.
    You are right about there being a lot of trade secrets in this line of work. That's why I was hesitant to even join up and start this thread. There are certain people that try to squash anybody trying to enter the field.
  10. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    The gooseneck does "transfer" weight to the tractor, but it's really not for the purpose of carrying weight like a normal trailer. It's to maintain traction and control.
  11. daf105paccar
    6,564
    7,293
    Apr 15, 2012
