Hustler Center Load Antenna
Discussion in 'CB Radio Forum' started by hawkjr, Sep 27, 2011.
  1. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    anyone has or had past experience with this antenna?? i plan on putting on my T660 along with an Wilson 1000... i just want to take off both of the factory whips.... but my buddy brought an Hustler Antenna for 37 bucks and never took it out the package so he was willing to let me bum it off him..
  3. am89
    am89 Light Load Member
    101
    12
    Aug 1, 2010
    METRO NYC
    Hustler has been making antennas for a LONG time.If it fits your application,why not?
    rabbiporkchop Thanks this.
  4. firebird1
    firebird1 Bobtail Member
    chicago IL
    Had a Hustler and the shaft snapped at the screw base Hustler is sending out a replacement
  5. am89
    101
    12
    Aug 1, 2010
    METRO NYC
    ...........Hustler has good customer service too!
  6. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    I have a pair on mine and love them.
  7. am89
    101
    12
    Aug 1, 2010
    METRO NYC
    I have the Hustler FG-27S.Google it.It's on a Firestik SS-204 mount.I made sure the coil is above the roof line.
  8. am89
    101
    12
    Aug 1, 2010
    METRO NYC
    When I'm stationary.I use a MFJ-1966.That's a 108", solid,stainless steel antenna.
  9. Happy_Hamer
    Happy_Hamer Light Load Member
    140
    40
    Aug 28, 2011
    Illinois
    They make a nice magazine too,,,,,,,,,,,,,,,, :biggrin_2555:
    Logan76 Thanks this.
  10. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    If you mismount both of the factory antennas and just mount one antenna, do not use the truck's co-phased cable setup.
    You do know that you will need 50 ohm cable ie RG 58, RG 8 etc. for a single antenna seup. Right?
    Whatever 50 ohm cable you obtain for a single antenna setup, it does not have to be 18 feet long. A shorter length like 9 feet, 12 feet or even less is actually a better idea. As long as it can connect the radio to the antenna, it will work well.
  11. mike5511
    mike5511 Road Train Member
    3,162
    1,549
    May 15, 2011
    NW Arkansas
    Theoretically you are correct. In actuality that won't prove to be true on some of the newer model trucks.
