Humming when ac kicks on engine fan
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Blue2547, May 18, 2021.
  1. Blue2547
    Blue2547 Bobtail Member
    7
    So I have a 389 with a 6nz in it recently it started to make a noise right before the ac kicks the engine fan on and it only does it with the ac on if you hit the fan switch it does not do it best way to describe noise it sounds like a train horn that barely has the valve open what could this be Thanks in advance
  3. Blue2547
    7
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Sounds strange. Does it make that noise when the fan engages for engine temperature?
  5. FLHT
    FLHT Road Train Member
    1,330
    2,262
    Aug 2, 2014
    Hose to fan hub leaking ?
  6. Blue2547
    7
    No sir not at all it almost sounds like it's coming from under the cab and whats really weird is you can't hear it from outside
  7. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    If the A/C is kicking the fan on, and that's the only time you hear the noise, could it be your expansion valve?
    Trucker61016, Blue2547 and skallagrime Thank this.
  8. skallagrime
    skallagrime Road Train Member
    3,836
    9,880
    Apr 10, 2012
    Indiana
    And if thats the case, the conclusion would be its on a slightly low charge because the compressor never gets all the gas compressed to liquid ONLY WHEN FAN IS ON and the hum is gas burbling through as well as liquid.
    (Sorry gpd, just wanted to finish that line of thinking so people know WHY that would happen)
    God prefers Diesels Thanks this.
  9. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    No, that's good. I didn't know why they made noise, I just remember they did. It's good to have the other half of the story.
    Trucker61016 Thanks this.
  10. Inderjit
    Inderjit Heavy Load Member
    716
    703
    Sep 17, 2017
    The fan normally kicks on when the refrigerant pressure reaches 250 PSI.
    The pump should shut off at 300 PSI to protect the system. I am wondering
    if the switch is failing and turning the fan on when the pressure is too high
  11. skallagrime
    3,836
    9,880
    Apr 10, 2012
    Indiana
    Technically its possible the valve is stuck too open, never really allowing liquid to build, but since its intermittent with fan, less likely.
    Gas to liquid and back is weird, especially when we start tampering with it in applied engineering.
