HUB OIL: levels etc.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, May 10, 2010.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    Can you tell me about hub oil---specifically on trailers.
    Everything about it.
    How to add and what type of oil do they take?
    arterialturns Thanks this.
  3. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    Just take the little rubber plug out of the cap and look with a flashlight if the lense is too dark to see through. There should be a line on the plastic the oil should be up to. They usually take 80W90 or 85W140. The rubber plug should have a tiny hole in the center to vent from, if you can't see a little daylight through it, take a straight pin and poke the dirt out of it. I don't know about the hubs that take grease or have the one piece cap, I've never been around them.
    A side question, anyone use Lucas hub oil? I've used it a little, seems really thick and sticky, but it also seems to turn black really quickly. I haven't used it long enough to tell how it lasts long term, anyone like it?
    Mjay and Powell-Peralta Thank this.
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I use & like the lucas oil. I use the oil stabilizer in my hubs. just about 20 % I like the way lucas clings to the bearings.
    RW. Thanks this.
  5. Mjay
    Mjay Bobtail Member
    21
    5
    May 18, 2009
    Alberta Canada
    Thanks RW , I didnt know about the pin hole vent. I recently bought a used trailer and when pulled a plug out, they was some built up pressure.
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Some trailers have grease packed bearings. Their caps will be solid with no plug, nothing to check until the wheel needs to come off.
  7. Powell-Peralta
    1,585
    240
    Jul 17, 2007
    OK, so in a pinch would engine oil----15W-40 or even car oil 5w-30/10W-40 do?
    The reason i ask brings me to the next question:
    2) i heard that if a hub does not get adequate oil, both wheels could fall off? Please discuss this fully as it could be a potentially hazardous condition.
    a) i've been writing the condition up, but i guess they haven't gotten around to it yet. So i feel i may have to take matters into my own hands etc.....
  8. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,164
    Jan 17, 2008
    Wherever and Whenever...
    The oil in the hub....just like the oil in the trans, and the differentials...not only serve to lubricate moving parts....It also helps to dissipate the heat generated since even though lubricated....there is still friction generated....
    I have seen the effects of improperly/neglecting maintaining the hubs....
    A driver for a contractor I where worked, almost bought it when the hub overheated and the wheel flew off on the highway.....
    Kind of hard to steer properly when you're missing a wheel.....
    After that....the company decided to add hub maintenance to their service program....
  9. springbrake
    springbrake Light Load Member
    211
    69
    Mar 13, 2010
    Ya think??:biggrin_255:
    Photograph A Overall view of tractor trailer with missing left rear tractor dual wheels (see white arrow).
    The heat damaged tractor trailer axle spindle is shown in Photograph B.
    Photograph B Overall view of axle spindle showing effect of long term heat resulting in wheel bearing disintegration and wheel spindle deformation from inadequate maintenance
    The trailer wheel bearing failure was caused by long term and extreme heat resulting from insufficient lubrication.
    RW. and Working Class Patriot Thank this.
  10. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    Inspect for hub oil leaking from the inner seal onto the brakes and inner tire sidewall. Add STP to slow the leaks until you can get repairs. Drive axle seals will also leak onto the inner sidewalls but the source of wheel bearing lubrication is the drive axle itself. Keep the drive axle full to prevent the bearings from running dry. Compare the heat of all hubs with your hand. You can also find a defective tire by comparing the heat of all tire sidewalls.
    RW. Thanks this.
  11. Diesel Dave
    8,522
    23,455
    Jan 20, 2010
    Hesperia, Ca.
    I use straight Lucas 100% on my trailer hubs and NEVER had a seal leak. I did coat both bearings first thought then added lucas.(when I changed over from regular gear oil). It takes awhile to get it in there but i Love it. Put it in my steer axle as well.:biggrin_255:
    mhyn and RW. Thank this.
