How to wire side camera and make come on when blinker is turned on
Discussion in 'Volvo Forum' started by Siinman, Apr 14, 2022.
  1. Siinman
    Siinman Road Train Member
    5,158
    12,910
    Mar 5, 2017
    Kansas City, MO.
    Bought a 8 channel camera system and it has the wires to hook up for when you put turn signal on or reverse and put it on screen. Any idea on where to wire those wires at? I have a 2023 Volvo 860.
  3. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    No idea. But a 2023 860! Nice!!! I'm jealous!!!
    Siinman Thanks this.
  4. Siinman
    5,158
    12,910
    Mar 5, 2017
    Kansas City, MO.
    TY Just got it after over a year waiting.
  5. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    I would explore wiring two relays from the turn signal lever/switch, one for each direction. Anything spliced into the lighting system is going to pulse off and on, so you have to find which wire is going to have constant current going through it when you move the lever.
    https://www.amazon.com/labwork-Signal-Switch-20797838-2005-2012/dp/B07X83H2TX
    It's a switch for older models, but it should be a similar concept.
    I would find which color wire is supplied a constant voltage when actuated up or down, then splice a wire to a normally closed relay that goes to whatever controls that side's camera. Do the same thing for the opposite side. I'm not sure how the camera communicates with the screen, but it's going to play a part in how you wire the other side of the relay.
    There might be a less complicated method, like just a switch instead of a relay. I would think it is better to isolate the camera side, so if any issues come up it's not on the same line as the turn signal current.
    Siinman and gentleroger Thank this.
  6. loudtom
    1,717
    2,800
    Aug 26, 2016
    You probably don't need a relay or switch. The switch is integrated into the lever. As long as the wire normally has no voltage, and supplies voltage when in that position.
  7. Siinman
    5,158
    12,910
    Mar 5, 2017
    Kansas City, MO.
    I have a master at wiring gonna look at it for me when I get to that point. I messed up and ordered a 4 channel and not a 8 channel based off the pictures. So gonna have to wait until the new one comes in. Guess I should have went after the words and not the pics.
  8. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    DVR should have signals input plug to connect brake light or turn signals. Camera recording all the time when you turn signal or push brake pedal the event will be recorded under video. Special viewer program needed.
    Ask DVR customer support or refer to manual.
