How to Use 2 Inch Ratchet Straps
Discussion in 'Flatbed Trucking Forum' started by farmerjohn64, Jun 27, 2020.
  1. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    Hi,
    I’m having trouble figuring out how to use my ratchet straps, something I’m practicing on right now, can someone tell me how it’s done? I think I figured it out after my second try, but I know there’s gotta be a better way to take it off because I’m fighting to get the one end without the hook out and through the spool, taking a couple minutes to do just that.
    Best regards, John
    D.Tibbitt Thanks this.
  3. blairandgretchen
    13,216
    70,220
    Dec 9, 2011
    South west Missouri
    For a start - WD40 or similar - so that ratchet turns and clicks freely.
    I leave the 30’ strap hooked, take ratchet off - opened all the way up, and pull hard - if your ratchet is oiled up it will Un spool ok.
    Worst case, turn the ratchet with pliers till strap can be pulled out.
  4. JonJon78
    JonJon78 Road Train Member
    7,041
    37,561
    Jul 1, 2018
    Its raining out but when it stops I will post a picture. When you feed it through make sure the tail end is on the outside towards your body not behind the strap as your ratcheting it.
    skellr, Wespipes, cke and 2 others Thank this.
  5. D.Tibbitt
    140,845
    If it dont turn, a pair of channel locks and u could turn it ... but what i do is open the ratchet all the way and pull on the strap from the backside of the ratchet and it should unspool
    kylefitzy, cke and farmerjohn64 Thank this.
  6. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    I gotta take a break because I’m aggravated with this haha I got one ratchet completely messed up because I can’t unspool it and I know I’m right there, but can’t figure out what I’m doing wrong. I think I’m connecting hook on the ratchet to the rub rail wrong because it’s getting in the way
    JonJon78 and D.Tibbitt Thank this.
  7. D.Tibbitt
    140,845
    Post some pics we could help u out
    Cattleman84, JonJon78 and farmerjohn64 Thank this.
  8. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
  9. farmerjohn64
    6,383
    38,746
    Jun 25, 2019
    I’ve been at this in the baking sun for a good hour, but now I feel happy now that I just figured out how to unspool hehehe
  10. D.Tibbitt
    140,845
    Unfortunatly all ratchets are backwards and they are designed to push up on them to tighten. But i like how ya got it , designed to pull down to tighten.... If ya looking to set it up like its designed to , take the ratchet off and flip that hook on the rub rail to the inside of it ... so the hook is facing outside rather than inside like u got it.... when u put the strap thru the ratchet and tighten, it will laydown properly with the strap.. But this way u will have to push upwards to tighten
    farmerjohn64 and JonJon78 Thank this.
  11. JonJon78
    7,041
    37,561
    Jul 1, 2018
    When I buy new ratchets I always take the bolt off at the bottom of the ratchet and flip the hook part around so that you arent ending up in this position...
