Not sure how to test if the heater inside my air dryer is working properly. I took off the wire harness leading to it, put a test light on it, turned the key and got nothing. Not sure exactly how to test if it is working or not. When the temperature goes below 16 degrees i can hear the purge valve barely opening and what sounds like ice purging out. With weather being so cold i want to make sure the heater is working. How do i go about testing the unit? Does the truck need to be running?
how to test if the heater inside the air dryer is working?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TowHaul, Feb 7, 2020.
What year/make of truck are you working on??? Either way it should be keyed power. But theres no standard from one make to the next until you start getting newer. Older Freightliners would grab power for the air drier heater off the reverse switch on top of the transmission. So if your reverse light works then it could be the wire is broken between there and the drier. But more often than not, the wires get switched around during a transmission install and makes the drier heater work only in reverse.
But your not driving a 2000 FLD, the. I can’t guarantee that any of that will actually help you...Cabinover101 Thanks this. -
But to test one they are pretty straight forward. Unplug it. If you have key power and ground then the truck side is working. To check the heater it’s self, ohm the twi pins in the drier. I don’t remember the temperature for sure, (maybe 40 deg) but it should show Open Circuit above and show a resistance below that ambient air temp.
In all reality it would be easier for my fat ### to run a new power and ground to a keyed breaker in your fuse panel. But I still like to keep things factory so I’d probably just try to stick my arm on top the tranny (no head) and do it by feel.TowHaul Thanks this. -
