How to tell when your clutch needs to be replaced.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BobbyTTour, Sep 4, 2012.
  1. BobbyTTour
    BobbyTTour Light Load Member
    83
    24
    Nov 30, 2010
    Spring Hill, TN
    I have an '01 KW with a C16 Cat and an 18 speed transmission that has around 870,000 miles. I bought the truck used and have no idea if/when the clutch has ever been replaced. A few weeks ago I was backing into a dock that had a slight upgrade to it. As I was backing in, the truck shuttered a couple of times and the clutch pedal lost it's free play. Shortly after this occurred I was able to get the clutch adjusted and it seems to be keeping the free play, but it has me nervous thinking that maybe it's time to replace the clutch before it leaves me stranded. The clutch does make some noise when the pedal is depressed which makes me think the throwout bearing is worn, but it still slides into gear without any issues.
    What are the warning signs of a clutch that is going bad? Could it be that the nut was slightly loose causing it to slip and lose it's adjustment?
    Also, I had a driver in the truck that complained about it getting stuck in gear, even when the gear shifter felt like it was in neutral. I've had this happen to me once since I've been driving it. Is this a clutch issue, or a transmission issue? I would think it's more of a transmission issue, but I thought I would mention here to find out if it had any bearing on what I experienced with the clutch.
    Thank you for your time.
  3. apyles
    apyles Medium Load Member
    449
    142
    Oct 21, 2011
    Newbern,Tn
    If it's getting that feeling like it's stuck is gear,it could be a transmission issue. A lot would have to depend on how it's been used. When the clutch starts going out, the symptoms, I have always had are grinding going into gear, creeping while the clutch pedal is pushed all the way down. Those are the 'biggies". But for a general opinion, sounds like the synchros are bad.
  4. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    i had your symptons. twice my clutch went out. first time was the throw out bearing broke and jammed up the pedal. but it gave warnings an hour before it went. the second time also had warnings for two days. loaded one day, unloaded the next day. warnings were off and on. but after unload that was all the clutch wrote.
    that clutch lasted a month. it got warrenteed but gave no warning whatsoever. stopped to pay the toll both and had no clutch brake. had to use the starter motor to get truck moving again. good thing the load was light. AND, i was not looking forward to delivering that load in denver during rush hour traffic. had to cancel my load home and went empty.
  5. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    A sudden major change in clutch pedal free travel or clutch brake operation.
    Grinding when going into lower or reverse gears from a stop and you can feel good clutch brake contact on the clutch pedal.
    Truck tries to creep with clutch pedal depressed.
    Noise coming from clutch area.
    Engine free revs in higher gears when on throttle under load.
    Clutch parts found in bottom of bell housing during clutch inspection/adjustment procedures.
    ChadFelix Thanks this.
  6. BobbyTTour
    83
    24
    Nov 30, 2010
    Spring Hill, TN
    Thanks for the information. It's not creeping, I don't feel it slipping, and it doesn't have a problem going I to gear, but from what I'm reading here, it sounds like it's on it's way out. I guess I'll be looking for a shop to do the work. Anyone have a recommendation for the middle Tennessee area?
  7. rollin coal
    rollin coal Road Train Member
    13,083
    25,868
    Mar 29, 2008
    TN
    T&K truck & trailer repair out of Lebanon, TN speak with Kenneth. Fair rates, good work they stand behind, and quick turnaround on a clutch job. They did a clutch in a friend of mine's automatic 780 Volvo in a day. Or Thompson CAT in Manchester.
  8. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    You might have them take a close look at the engine mounts first before you commit to a clutch job. Since the sudden change in your clutch took place when you were backing up a grade loaded, the engine may have shifted enough to affect the free travel adjustment on the clutch through your clutch linkage. An 01 truck with 870,000, might be time for mounts.
    Oxbow and pigeon river trucking Thank this.
  9. BobbyTTour
    83
    24
    Nov 30, 2010
    Spring Hill, TN
    I had the mounts checked last year, but I will definitely have them checked again.
    Thank you for the recommendations Rollin Coal, I'll give T&K a call. I've used Thompson Cat in LaVergne to for their dyno, I never thought about checking with them on the clutch.
  10. rollin coal
    13,083
    25,868
    Mar 29, 2008
    TN
    I can't say that I recommend the LaVergne shop, never used them for anything other than a dyno myself. They may be good I dunno, they are a "mega-shop". The Manchester shop is much smaller and local to me - I've used them for years, they are good folks not your typical rip off dealer type shop. Their wrenches are paid by the hour - not by quickest half@$$ed turnaround on jobs, they'll do it right the first time be on quote and competitive. I would likely have them do a clutch job just because they're so much closer to me than T&K but the T&K shop is good and I have used them before. Definitely do as bender says and check your motor mounts first that would be a much cheaper easier fix, if it is the problem.
  11. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    When you can't adjust it anymore, it's time.
    When you hear grinding noise during clutch operation, it's time.
    When it's in gear but it doesn't go and you wonder what that stinky smoke is, it's time.
