How to take highway curves?
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Jul 6, 2018.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    842
    1,616
    May 15, 2017
    Taking a load of fiber today, weighing 42864 pounds, gross weight 76,500.
    I'm driving along the highway (I-77) on some portions the speed limit is 70mph. Figured no problem my truck is governed to 63mph anyway. I'm doing these curves at 60MPH and it feels like I'm going to fast? Meanwhile there's trucks passing me every 30 seconds doing like 70-75 on the same curves? How do you know if you're going to fast for these curves? I felt like my truck was leaning hard on some of those turns even at 55MPH. Did 10 weeks of training with my carrier and nobody was able to give me a proper answer on how fast you can take curves.
    Any ideas?
    -Thanks, from a new driver.
    Attached a picture of the load.
    magoo68 Thanks this.
  3. 06driver
    06driver Road Train Member
    2,436
    3,434
    May 28, 2017
    Kind of like downhill. You can do it to slow a million times, but to fast only once.
    Seriously do not worry about how fast someone else is going. They may be empty, they may be a low load, they could just have a little more power so they can pull through the turn.
    It helps if you can tug on your trailer as you go through the turn. Not hold it to the floor acceleration, but a good steady pull you can maintain through the apex.
  4. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    Most ppl find out they are going to fast for a curve when they are driving in the ditch. Untill than you are fine.
    RedRover, LoneCowboy, Smut and 5 others Thank this.
  5. skittlz
    skittlz Bobtail Member
    10
    16
    Jul 9, 2012
    The reason they couldn't answer is that there is NO proper measurement. I remember a job I had doing a dedicated run. One day they increased the load per truck and we had two drivers tip over on the same ramp at the same spot. There is no defacto on how fast you can go around bends you just have to feel your truck and your load with one sobering rembramce in mind. You can go too slow all you want but you only get to go too fast once. Who knows those other trucks might be empty, might be loaded with freight soo heavy it's only 3ft tall. Dont worry about what their doing driver get ur load where it's going safe and secure the rest will come with time, just remember you only get to make that mistake once.
  6. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    If the load is stacked Hi inside trailer and heavy it will need to driven slower around curves to keep leaning to a safe limit?
  7. austinmike
    86,139
    Go with your gut. If it feels too fast then slow down. When I was brand new other trucks would blow my doors off lol. It takes time to get the feel of what your truck can do
    Bean Jr., TravR1 and Canadianhauler21 Thank this.
  8. thaistick
    thaistick Road Train Member
    1,416
    1,737
    Dec 7, 2014
    OTR/Thailand
    Go as fast as you feel comfortable and safe.... As mentioned above there is no set answer with the exception of the being at or below the speed limit. And don't worry about what other trucks are doing, let them drive their trucks and you drive your truck.
    Bookhacker and Canadianhauler21 Thank this.
  9. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    If it feels too fast, it is too fast. I generally go 5 to 10 slower than what the sign by the curve says the first time or two I go around and then start hitting it a little faster if it feels like it's safe to do so.
  10. Lab work
    Lab work Medium Load Member
    551
    673
    Apr 20, 2018
    USA
    Sometimes I get dispatched to Washington for a load of apples. They are the worse loads for the curves. They always stack the pallets high. A big difference between the load of apples and a load of pharmaceuticals.
  11. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    There is no correct maximum speed as each load will have a different Center of gravity .. low and heavy can go quicker without leaning as opposed to a double stacked load ... your doing it right by trusting your sense that it’s leaning
    Smut and Canadianhauler21 Thank this.
