How to stop horn beeping when driving slow?
Discussion in 'International Forum' started by rtfirefly, Jul 29, 2021.
  1. rtfirefly
    rtfirefly Bobtail Member
    4
    4
    Feb 20, 2017
    Driving a new automatic international truck.
    Sometimes, when I slow down to get myself ready to back up my trl, the truck's horn will start gently beeping in a consistent rhythm. It'll beep either driving forward or backwards and it wont stop until I shut off the engine. Nothing shows up on the dash to indicate any problem, all my gages are functioning normal, and my doors are properly closed. As I said, this does not always happen, and as far as I can tell, there is no significant difference in what I do when it beeps and when it doesn't beep.
    Least to say, I find the beeping very annoying, but am unable to figure out how to make it stop. Does anyone know what I need to do or stop doing in order to make this annoyance go away?
    Thank you.
  3. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    My city horn would randomly make noise. I just disconnected it.
    truckdriver31 Thanks this.
  4. rtfirefly
    4
    4
    Feb 20, 2017
    Company truck. No can do unfortunately...
  5. Flat Earth Trucker
    4,054
    14,903
    Nov 19, 2018
    Find a diesel repair shop run by latinos. They'll fix you up. Of course it'll be on your own dime.
    truckdriver31 and Kyle G. Thank this.
  6. supersnackbar
    18,606
    44,764
    Aug 19, 2007
    Your Town, USA
    Mine beeps like that if I don't have my tractor brakes set and I open the drivers door. Perhaps the door switch is malfunctioning, then when you release the brakes to leave, the computer thinks your door is open.
    InTooDeep, truckdriver31 and Heavyd Thank this.
  7. slow pok
    slow pok Light Load Member
    144
    211
    Oct 27, 2013
    lizela ga
    Your company has it programmed that way
  8. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    A constant rhythmic beeping is due to improper safety interlocks such as door open while parking brake not set, or key off with parking brake not set or sometimes if programmed, no seat belt. There may be others too, but like mentioned, a door switch or other sensor may be faulty and setting a false state to cause this. You may need to visit a dealer if you aren't causing any infractions yourself.
  9. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    your door mite not be shut all the way. check driver and pass door.
  10. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    Cattleman84 Thanks this.
