How to stop a minor fuel leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Patriotleasing, Jan 1, 2017.
  1. Patriotleasing
    Patriotleasing Bobtail Member
    28
    Jan 1, 2017
    Got a hairline crack in the weld around the bulkhead underneath my right side tank. Not visible to the eye but the drops sure are. It's an aluminium tank. Any suggestions on what to use to permanently patch it ?
  3. AModelCat
    154,582
    Best way IMO is take it to an aluminum fab shop and get it welded. If the tank is properly cleaned out I can't see why they wouldn't weld it.
  4. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Yep, with tanks like that,we remove them, drain them, and send them out to fab shop for a patch piece to be welded on.
  5. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    The OP probably figures by time you remove them,send it out then re-install..Might be cheaper to buy anew 1.
    He just wants a quick patch (If possible)...........I know you can get a new 1 for bout $5-600
    Not everyone's got a toasty warm shop to do stuff like this
  6. AModelCat
    154,582
    I wish I had a nice warm shop to work in lol. The big issue is finding a product that will cure while diesel is trying to wash it away. Sealers and epoxies don't typically bond well with petroleum contamination. So regardless you will more than likely have to drain and clean the tank out anyways. What's an extra 15 minutes to unhook 2 tank straps, 2 fuel lines and an electrical plug?
    passingthru69 Thanks this.
  7. stayinback
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    lol, Oh Sure- Caked on Fuel Lines Always come right off without persuasion...Strap bolts Never Break upon removal- Try a Few hours With an older truck..
    But ,It probably is the best way to Go- Save a Few Bucks anyway
    ramblingman Thanks this.
  8. Oxbow
    Oxbow Road Train Member
    12,483
    128,255
    Nov 24, 2015
    Believe it or not a bar of soap works well for temporary repairs. I used that trick once in order to burn the fuel down to below where the damage on a tank was, and then patched it with good ole JB weld with the intent of replacing the tank when it was convenient. The JB weld repair was still holding when I sold the truck.
    As NorthernMechanic suggested, if the leak is on a seam or hole in the bottom of the tank that cannot be dried up, then removal and repair/replacement is probably the best option.
    fargonaz, wore out, Roger McG and 3 others Thank this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I used a marine grade epoxy suitable for aluminum. My tank leaked in behind the straps, many pin holes. I used a Dremel to route out all the holes and white corrosion. Sanded it and cleaned it off with alcohol, I think.
    Then applied the epoxy. After the strap was in place you couldn't tell that I did anything. I drove the truck for a year and a half after that and traded it off. No problems with it.
    Oxbow, SAR and mhyn Thank this.
  10. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
    Paraffin wax and jb weld, spread the wax till it stops leaking and then jn weld it.
    Oxbow Thanks this.
  11. bzinger
    bzinger Road Train Member
    16,598
    65,777
    Dec 10, 2014
    omaha , ne
    I have a former employer that patched a hole in the side of the block on series 60 with JB weld .
    That was 2 years ago and it still runs lol.
    Oxbow and wore out Thank this.
