How to shift a 7 speed freightliner
Discussion in 'Questions From New Drivers' started by woothetrucker, Oct 21, 2017.
  1. woothetrucker
    woothetrucker Bobtail Member
    12
    Oct 21, 2017
    I just started working for coke and yesterday was my first day driving and I had no idea they drove 7 speeds I thought all thought all their trucks would've been 10 speeds or autos....I noticed what I learned in school that 2+5=7 3+5=8 doesn't work on this truck I also noticed when I upshift it have to be around 1800rpms but downshifting I am completely lost I'm just really getting lucky I.e. Red lights,stop signs, and the stores I had to deliver to that's when I slow all the way down and throw it in second
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Is it a five and two? A five speed transmission coupled to a two speed rear end?
    One I drove way back, you shifted the first five gears, flipped up the two speed rear and went back into fourth on the transmission (6th), then shifted up to five again (7th).
  4. woothetrucker
    12
    Oct 21, 2017
    It's straight to 7 it's no splitter
    uncleal13 Thanks this.
  5. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    dngrous_dime and tinytim Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I think that is either a straight 7 or a two speed rear. That rear will have to be flipped twice on every shift.
    It would be much easier to simply examine the shift plate inside your cab mounted somewhere in view and it will tell you what the pattern is.
    When she starts bucking if the RPMs are too low then you found the torque RPM number.
  7. 201
    12,044
    24,581
    Apr 16, 2014
    They claim it's a straight 7, no splitter. This person is doing what most people who have trouble downshifting do, they are over revving the motor, and missing the "spot" for the next gear.
    x1Heavy Thanks this.
  8. MACK E-6
    48,113
    219,511
    Grubby and 201 Thank this.
  9. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    Well, that can be solved easily with the engine manual that shows the torque and hp chart with the exact RPM's for both low and high.
    My spouse was a overrevver with that 13 we had in the T2000, she would grind the hell out of it while the radio lit up with posion. HEY!! 45 mph, kick it up, it's 70 out here... Sometimes Ive eased out of sleep, notched her into gear and away she went.
    She turned into a torque monster once she found that RPM at which the truck will take any gear. What a ride... HAW...
    201 Thanks this.
  10. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    Truck manufacturers do in fact manufacturer a 7 speed tranny (or the transmission manufacturer does) just for some city trucks because no need to have 10 speeds to run around city limits making deliveries where you might only get up to 20 mph between stops. Also the engine is a small 275-300 HP. Just shift it one gear at a time, probably don't even need to get to 6th or 7th, right ?
    lovesthedrive and JReding Thank this.
  11. MACK E-6
    48,113
    219,511
    I have a 10 in my single screw. OP may have a straight truck.
