A common complaint among team drivers is the inability to sleep in a moving truck. Sleeping in the top bunk is impossible because it shakes so violently, and the bottom bunk isn't much better.
If anyone has successfully rigged up a hammock system to reduce or eliminate motion I'd like to see pictures of how you did it. I'm trying to figure out a system of using eye bolts and carabiners to rig up the hammock, perhaps with bungies to act as shock absorbers. Carabiners would allow you to install the hammock when the truck is moving, and quickly take it down when you have the luxury of sleeping on the bunk if the truck isn't moving.
In hotter weather a net hammock would also give anyone (solo or team) a better way to sleep with complete ventilation around your body, without having to resort to running an APU or idling to keep the air conditioning on. In colder weather you can stay warm by wrapping a sleeping bag around the hammock so you have insulation on the bottom side that isn't compressed under your body weight.
How to rig a hammock in a sleeper
Discussion in 'Experienced Truckers' Advice' started by Lepton1, Apr 4, 2013.
Page 1 of 4
Don't know but you better be able to get that belt round you or you may have a DOT issue.
Brickwall Thanks this. -
Instead of the standard bunk belt I would opt for wearing a harness like a rock climber, then clip that into an eye bolt on the back wall. I have experience sleeping in hammocks on big walls, like El Capitan in Yosemite. During our multi-day climbs we were never unroped until we summited. Big wall hammocks are single point suspension (usually with at least three anchor points equalized to one locking carabiner) and we had a separate set of anchors to secure the rope we had tied into our climbing harness. With a two point suspension hammock in a sleeper (like a navy hammock) it should be easy to simply rig a small rope to the back wall or ceiling with an eye bolt and clip that into a harness.
Buster Churry, otterinthewater and x1Heavy Thank this. -
WoW !
A hammock will still bounce roll and swing regardless while in motion,
once authorized try and build a custom frame install prototype, roll bars included behind the safety nets ... tie off .. good luck -
Don't have pictures, because I did that years ago. I had it rigged 2 ways, one was diagonal across the sleeper berth and the other was diagonal across the drivers cab compartment. Of course the one in the drivers cab was only used when the truck was parked. Didn't need any type of shock absorber when moving down the road; the materials had enough give to absord the movement of the truck. Could stow either, cab or sleeper, with a bungee mounted on the overhead. I learned to use a very heavy eyebolt, because most are made of soft metal and will open with a relatively heavy person. Mine opened and I weighed 175 lbs at the time. Stainless steel eyebolts can be purchased at a marine supply store. For the hammock I used a camper hammock made of something like mesh or heavy fishnet with a blanket laid across it; didn't have room for anything larger.
I would expect there will still be motion. However, hammocks have been used on sailing boats and navy vessels in order to reduce the motion from wave action. Even without shock absorbers there should be a significant reduction in violent motion, and it may turn that motion into something more calming and gentle than the sometimes painful motion of internal organs being shaken when the truck goes over bumps.
points taken, so why aren't they standard issue?
You'll get used to the motion of the truck. If I can sleep with a loaded milk tank (bucking from the slosh) in winter (ping, ping, ping on the back-wall of the sleeper from chunks of snow flying off the drive tires), you can learn to handle sleeping on the bunk.
Used to be the norm back in the day...called them swinging bunks.
A simpler solution is to refuse to work for companies that require you to run teams.
Russian Rabbit, ChaoSS, insertnamehere and 2 others Thank this.
Page 1 of 4
