How to replace shifter rubber boot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Skate-Board, Sep 15, 2014.
  1. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    I need to replace my rubber shifter boot but don't know what I'm in for. I did notice there is a screw on the back of my shift knob. Should I attempt this or let a dealer do it? I don't want to take this apart then be stuck because I can't do it. It's a direct 10 speed Eaton
  3. 201
    201 Road Train Member
    12,052
    24,605
    Apr 16, 2014
    high plains colorado
    Hi Skate-Board, it's not that tough at all, I think the Scarecrow could do it, after his visit to the wizard, that is. You have to take the air lines off, and mark them, there's only 2(I think) and the shift knob should unscrew, feed the air lines through the new boot and screw the knob back on and attach the air lines. In the old days, you had to replace the brass ferrules, but I think the new ones don't have that.
    Skate-Board Thanks this.
  4. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    [QUOTE="semi" retired;4239605]I think the Scarecrow could do it, after his visit to the wizard, that is.[/QUOTE]
    Lol.....Out of stock so this could be a problem
  5. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Like semi retired said. But my knob has 5 air lines. When I took my fittings/air lines off the underside of knob, all the ferrules came off in two pieces. Easy solution I went to my local hardware store and bought brass ferrules they sell in the plumbing parts. Not sure if they are DOT approved but they work.
    IT is easy just mark the lines before you take them off. If your memory is like mine or take a picture first, that's works good also. Good luck
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Once you get the knob off, the boot itself is just some screws (6 or 8). You may have other trim that needs to come off 1st depending on the truck. Most are phillips screws, stick a screwdriver in them, then give a few sharp smacks with a hammer on the back of the screwdriver. It helps break the corrosion and you have a better chance of getting them out without stripping the heads or breaking them. If you have one, a hand impact driver works great on them if they're stubborn.
  7. 9200 IH
    9200 IH Bobtail Member
    35
    5
    Jul 26, 2014
    You could have a vibration isolator just above the transmission on the shifter rod. If you do take the bolt out of the isolator lift the shifter out of the boot and put the new boot on.
  8. 201
    12,052
    24,605
    Apr 16, 2014
    What about the air lines?
    maggard359 Thanks this.
  9. xsetra
    5,094
    6,941
    Aug 21, 2011
    [​IMG] Originally Posted by 9200 IH [​IMG] You could have a vibration isolator just above the transmission on the shifter rod. If you do take the bolt out of the isolator lift the shifter out of the boot and put the new boot on.
    Ohhh just cut em.
  10. 9200 IH
    35
    5
    Jul 26, 2014
    I thought taking the bolt out of the isolater if he has one was easier than taking the knob off and the air lines have to be un hooked no mater what. I thought that was a given.
  11. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    The knob is easy. The air lines should be color coded. Take a pic with your phone so you put them back in the correct place. Loosen the lock nut and unscrew the shifter. Install new boot and put it back together.
