How to replace cab air bag?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by vadim2200, Jun 20, 2011.
  1. vadim2200
    vadim2200 Light Load Member
    128
    36
    Nov 21, 2010
    on my KW t2000 1 of 2 air bags that holds the cab has crack and leaking air and the cab doesn't inflate, just being held by shocks and rubber pad. Can someone tell me the proper way on how to remove that bag. It has air fitting on the bottom and 1 bolt on top. I was thinking about:
    1. unscrew bolt & unplug air line
    2. block that air line
    3. turn on the truck and let the other bag inflate
    4. using leveling valve raise cab even more
    5. remove bag upwards.
    please correct me if i am wrong, or if i need to add more steps
  3. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    put a jack in between cab and crossmemeber--then dump all the air
    vadim2200 Thanks this.
  4. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    I think you can do it that way, just be sure to block the cab up before you start working under it, I wouldn't trust that one bag holding it up with my hands and arms underneath it.
    Diesel Dave and vadim2200 Thank this.
  5. Nevs
    Nevs Light Load Member
    295
    107
    Dec 25, 2010
    flyover country (Iowa)
    Amen to that! Block it up before working on it.
  6. vadim2200
    128
    36
    Nov 21, 2010
    just changed it, took me 25 min, didn't even tried to raise the cab,
  7. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Many times you can just take a pair of pliers, and squeeze the line to the leaking bag and the other bag will lift it, then you inset the block, and change the bag. It gives more room. If you got it done good for you!
  8. AfroBat
    AfroBat Medium Load Member
    343
    68
    Jul 24, 2008
    Los Angeles, Ca.
    Hey what size wrench or socket did you use? I got a freightliner 04. Got a one bag leaker :(
  9. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Save yourself some trouble and replace both bags.
  10. AfroBat
    343
    68
    Jul 24, 2008
    Los Angeles, Ca.
    Yes I found out yesterday my new ones is working the old one needs replacing and well I gotta shop for used and found one till I can get on my feet. Being an O/O is no walk in the park! :)
  11. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I'm looking forward to my day :)
