How to repair a tire pressure gauge?
Discussion in 'Experienced Truckers' Advice' started by A Bug, Jan 5, 2019.
  1. A Bug
    A Bug Heavy Load Member
    827
    1,576
    Mar 15, 2014
    Sevierville TN
    It does not take long before that little rubber ring gets worn out and you can no longer get a good seal to test the pressure accurately.
    What do you use to fix this besides just buying a whole new gauge?
  3. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Buy a quality gauge that doesn't wear out. Stop buying truck stop junk.
    Other than that, simply ignore checking tire pressure. Most people do anyway. :)
    (Yes, that was a joke....)
  4. Moosetek13
    Moosetek13 Road Train Member
    14,521
    17,999
    Nov 1, 2010
    Burnsville, MN
    And a new one costs SO much that you can not afford it?
    Find a new job.
  5. Omega1
    Omega1 Heavy Load Member
    721
    1,598
    Nov 18, 2017
    Oregon
    And the hits keep coming. There must be something in the air tonight or the moon is out of alignment.
    IluvCATS, towmantater, Lepton1 and 5 others Thank this.
  6. A Bug
    827
    1,576
    Mar 15, 2014
    Sevierville TN
    You only needed to say that you do not know.
    Farmerbob1 and JonJon78 Thank this.
  7. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    I heard you can use your points. Something you accumulate every day. To buy that tire gauge for FREE.
    Or was that just counter talk?
    It's highly unlikely you're going to find a new seal.
  8. Espressolane
    16,994
    102,530
    Solar eclipse today, lunar eclipse in about a month.
    Bean Jr. and Omega1 Thank this.
  9. TIMPTE 527
    TIMPTE 527 Medium Load Member
    608
    827
    May 28, 2018
    When ever I go to Speedco for oil change I calibrate my gauge against their's. Mine has been exactly 5 psi lower for the last 5 years. So I know when I inflate to 115 psi I'm only at 110.
    Lepton1 Thanks this.
  10. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Id use Loves points for a new $12.99 new one,unless you can source an o-ring? I have $260 ,just on Loves points (yes,Ive drove a lot)
  11. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    O Rings & Things
    When you're in Fontana, CA, you can stop here and get a 5¢ O-ring to fix your tire pressure gauge.
