How to remove slack adjuster with a weld clevis on push rod.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kitCat, Nov 9, 2013.
  1. kitCat
    kitCat Light Load Member
    97
    38
    Oct 13, 2013
    I went to adjust the brakes and one of he slack adjuster is frozen. THe adjusting hex nut won't turn at all. I was thinking about replacing it since its bad, do I have to take the air chamber off since the clevis is welded to the push rod? Btw all the slack adjusters don't have a grease fitting on them
  3. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Since the slack will not adjust, you can't back it off to clear the yoke/clevis either. Once you have the clevis pins out, you would have to just unbolt the brake chamber from the mounting bracket so the slack adjuster will clear the yoke/clevis.
  4. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    You could just cutoff wheel the slack adjuster. Depending on what you have, you might want to replace both slacks and cans while you are at it.
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    Ya try heating up the slack to soften up the old grease to get it to adjust? That would be my first step. Just a propane torch or even a heat gun might work.
    If no luck, then break out the tools of destruction. cut-off wheel or O/A torch.
  6. kitCat
    97
    38
    Oct 13, 2013
    Thank you for the advice. One more question the dealer wants freaking $94.00 for a automatic slack adjuster, can I change it to a manual slack adjuster? Manual is only $10.00 I will change both if I can convert?
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
