Guys, whats the secret/trick in removing those 3 large headed bolts that hold on the front 16" mud flaps?
I have been soaking the nuts down with panther pi$$ but not sure what to hold the top of the bolt with? - its a rather LONG/LARGE slotted head..
How to remove front mud flaps W900L ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Sep 4, 2010.
Page 1 of 4
Flat head screwdriver....
Are you really asking this question?? -
If I am not careful or use the correct tool, I will indeed damage these bolts.
Now, if them come in S/S - then I might not care, but they are painted to match and not sure about replacing them. I have heard they are KW only....if you want that design.. -
A piece of steel held in a pair of vise grips is how I did mine,
Hanadarko Thanks this. -
-A good cold chisel in a good pair visegrips will get them out ...And as for breaking them put in a good ss bolt and forget it
Did you just replace the bolts with SS and like a fender washer or ?
Thanks- -
I think they was 1/2 bolts about 1 1/2 long ..they are called a carriage bolts . They have a big head on them so you dont need a washer on hte outside but put a fender washer on the inside with a teflon nut
I belive you can order the right style bolts in stainless
A fender washer and an ss bolt would work just fine though. -
Well they aint coming off...not sure what to do next. I dont mind destroying them but got to them them off someone....
Page 1 of 4
