How to regen - International 2020 - cummings engine -
Discussion in 'International Forum' started by JerryD13, Dec 9, 2021.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    QUESTION > How do you REGEN a Cummings 2020
    The reason for this is getting REGEN ERROR - messages - and Now asking for REGEN
    in error messages, look at the image attached.
    UPDATE :
    SO HERE IS HOW OUR TECH FIXED REGEN ISSUE -- NO CHIPS INVOLVED !!!
    The attached images -- shows the PART that was changed out
    ON DEF TANK -
    $ 250.00 part.
    * plus after install he did a computer forced re-gen - all good now.
    Reason for edit: edit
  3. craig_sez
    craig_sez Road Train Member
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    Are you parked? They dk a partial re gen on the move but you dont notice it..
    If your maxys are pulled,out of gear and you try to engauge the regen and nkthin happens,might be an option not turned on within the ecu..
    When she needs to regen it will do it on its own but again for a full regen you gotta be parked,brks applied and running..
    JerryD13 Thanks this.
  4. JerryD13
    169
    126
    Oct 17, 2016
    no luck yet.
    with the motor on .. and brake set and I PRESS the REGEN button
    nothing happens, I also held for 7/15 seconds, and nothing ?? no regen
    NOW for sure the company resets the regen from a REMOTE LOCATION
    with a laptop .. but the tech did not know how to start regen on the truck.
  5. Brandt
    Brandt Road Train Member
    4,403
    5,936
    Sep 17, 2012
  6. AModelCat
    154,242
    If it doesn't need it, it probably won't do it.
    No point in forcing a regen for no reason.
  7. craig_sez
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    1st why are you trying to regen?
    If tech cant get it to regen then its nothin to do with company unlocking it or tech is a #######..
  8. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Ok, first of all, it's Cummins! Not Cummings! You can only force a regen with Cummins Insite or other diagnostic software. If the truck isn't requesting a regen, you cannot start one with the dash switches. Regens do not clear or correct DEF related faults. Regen is a separate aftertreatment system compared to the DEF system.
    AModelCat and QUALITYTRUCK Thank this.
  9. AModelCat
    154,242
    The part about regen having nothing to do with the SCR system falls on deaf ears 99% of the time.
    Heavyd Thanks this.
  10. L3v1s
    L3v1s Bobtail Member
    12
    Dec 8, 2014
    If you're parked and on high idle the truck won't go into regen by itself. It will throw a message asking for a parked regen, but even if you press the dash switch it won't do a regen with the RPMs up. It will only go into regen if you're on low RPM idle.
