How to read my odometer??
Discussion in 'Volvo Forum' started by Supertrucker1982, Jan 17, 2019.
  1. Supertrucker1982
    Supertrucker1982 Bobtail Member
    Hello. I have a 2005 volvo VNL and the odometer reads 150750.1 miles. It seems to me that it’s missing a number. I know have over a million miles but is it 1,150,750 or do I have 1,507,501. Please help
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    .1 is a tenth of a mile,
    So your odometer reads one hundred fifty thousand, seven hundred fifty and one tenth of a mile.
    But you probably reached the odometer’s limits as far as placing a digit into the million place so it’s probably 1,150,750.1 miles.
  4. Supertrucker1982
    Yes that’s another way of looking at it but according to owner , odometer has never been replaced and truck has over a million miles. I’m so confused
  5. boneebone
    2,294
    2,365
    Mar 13, 2009
    I have a 2001 Volvo that is almost at one million miles and there’s no place on the digital odometer readout for another number, so when it turns one million miles, it will read 000,000.0 again.
  6. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    It's also possible that the original odometer went kaput and had to be replaced at some point.
    If that happened, it's SUPPOSED to be reported to you upon purchase...
    But..
  7. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    On that cluster style there is provision for million miles number but it’s also true in 2001 it. Was not the case. Note of both cluster it is possible to reprogram the cluster with the correct milage using Volvo software but the cluster involve need to have the same serial number than the truck. Also the eecu keep the total milage of vehicule in memory for reprograming reference if require. Ben
  8. BCV
    BCV Light Load Member
    233
    436
    May 26, 2018
    Go on ebay and buy a fresh one that starts at zero
  9. Sdatruckinginc
    Sdatruckinginc Bobtail Member
    46
    20
    Jan 18, 2019
    When u change a cluster on Volvo it has to be programmed that puts mileage and parameters to match your vin it’s not a plug and play
  10. benrab
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    There is two possibility , use a blank cluster from dealer inventory and program milage and S N of the truck at the dealer garage OR order a clister through the dealer parts system already programmed with the correct SN and the milage you wish. That one will be plug and play.
  11. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    I have pictures on my old phone showing the millionth mile. I stopped at 999,999.9, then rolled forward to 0.0. There were no extra zeros...just 0.0 miles showing.
