How to read and use oil analysis?
Discussion in 'Ask An Owner Operator' started by jpeters72155, Apr 27, 2015.
  1. jpeters72155
    jpeters72155 Light Load Member
    219
    18
    Sep 17, 2014
    Hello Truckers report users. I'm learning a lot about the trucking industry and now I'm on oil analysis. I know that companies like BlackStone labs can do this but how do I really read and use the results? I know I can go to a mechanic to help me out but I want to learn some stuff on my own so I know what they are talking about at least a little.
    I have a report ready to look at if someone wants to help. I'll even hire you as my go-to oil guy/gal in the future or mechanic reference. I'm helping out with a big truck purchase for a small fleet so I need some good help. Thanks!
  3. Badcable
    Badcable Medium Load Member
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
    Well, in all honesty, you can probably get a pretty good, low cost (free) education here. Share the results and inform us of the setup on the vehicle, where, and what you're hauling. There's alot of experienced pro's here that'll help out I'm sure.
  4. Travisroland
    Travisroland Light Load Member
    236
    139
    Apr 2, 2015
    You can always call into Kevin Rutherford's talk show.He is always analyzing someone oil on his show.Check out Lets truck with Kevin Rutherford
  5. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    That name tends to cause rage on this forum.
    dannythetrucker Thanks this.
  6. me myself and I
    me myself and I Heavy Load Member
    731
    312
    Oct 5, 2009
    vernon hills,Il
    Every oil analysis I've seen had a summary. That's what I would go by
    jbatmick Thanks this.
  7. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Wish I knew more myself. Thankfully DY posted a Detroit threshold chart I've saved. The lab will flag anything that would be abnormal. I'm still too scared to push my drain intervals too hard. Every lab test result I've received will have an overall condition status. Mine have always just said normal.
  8. blairandgretchen
    13,212
    70,209
    Dec 9, 2011
    South west Missouri
    I use Schaeffer Oil, and their test lab - the rep will call you to discuss the sample if there is anything unusual. I'll be installing bypass filtration shortly to extend the drain intervals - from 13,000 currently to 30-50,000 monitored by the samples.
    Cowpie1 is a good brain on the samples and wear metals/additive packages etc.
    Post the sample here if you like so folks can pick through it with your questions.
  9. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Here are the manufacturers "condemnation limits" as aggregated by the state of California (in studying extending oil changes on state-owned vehicles):
    Theoretically, until the oil samples outside of those limits, it doesn't need to be changed.
    You also use oil analysis to monitor trends to see if anything starts climbing at an unusual rate. For example (I'm making these #s up), your engine might normally add 0.2 soot for every 10,000 miles so when your engine starts adding 0.5 soot every 10,000 miles you might consider running an overhead.
    Here is an overview:
    icsheeple and nofilter Thank this.
  10. MZdanowicz
    MZdanowicz Light Load Member
    221
    207
    Apr 7, 2013
    peabody, ma
    Hey Sales- Go to this site and forum, bobistheoilguy.com. They had all the answers on how to read oil analysis. I just got a good education at this site. Everything about oil is here and more. Mike-Z
  11. jpeters72155
    219
    18
    Sep 17, 2014
    Hey guys, sorry for the late reply. I tried to learn everything that you guys posted about. Here are the 2 reports I have:
    Unit 1 above
    Unit 2 above
    Could you guys give some feedback? All looks normal no? Now this is the seller's own analysis. What are the chances that the seller tampered with the oil analysis somehow? Is that possible?
