How to put some grease in trailer axle bearings, without taking them apart?
Discussion in 'Freightliner Forum' started by Verdel, Mar 8, 2014.
  1. Verdel
    Verdel Medium Load Member
    596
    135
    Oct 26, 2013
    Is it possible to put some grease in the trailer axle bearing, if I install grease fitting (zerk fitting) on the hub caps and start pumping until start showing from the other side? Any body had experience with greasing axle bearings without taking them apart?
  3. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    It will work, but will a take a huge amount of grease to fill the back bearing, not real practical. I have done that on farm equipment, but the capacity was much smaller.
    Verdel and DoneYourWay Thank this.
  4. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Either get a set of bearing buddies or drill a tiny vent hole so that you do not overpressure the grease and push the seal out the back side of the hub. Bearing buddies are designed for exactly what you intend to do, they have a spring loaded plate to keep pressure on the grease and in the bearings, they also have a vent hole to indcate when the cavity is full.
    DoneYourWay Thanks this.
  5. Verdel
    596
    135
    Oct 26, 2013
    I agree with you, but because, I don't have tools for heavy equipment, paying someone to repack all the bearings will cost more than the grease it self. My only concern is, if the hub is full of grease, may start leaking to the brake shoes.
  6. Verdel
    596
    135
    Oct 26, 2013
    How exactly these "bearing buddies" look? If you can give me a link for this.
  7. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Just google "bearing buddy".
    gpsman Thanks this.
  8. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    your trailer isn't an oil bath system, that uses hub oil? most over the road trailers you pop off the plug and pour in hub oil. it usually light duty trailers with grease trailer bearings
    DoneYourWay and gpsman Thank this.
  9. jbatmick
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    Kind of what I was thinking. Most trailer hubs take oil.
  10. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    OP,you forget something.
    If it is time to put new grease into a bearing then it is also time to check the wear off the bearing.
    So you are not paying someone to grease them,you are also paying him to make shure your bearings are still in good shape.
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    when I bought my flatbed rated to haul 80,000 lbs. it came from factory with grease in the hubs. not oil. 1 bearing went out & I liked the ides of oil better than grease. I had the truckpro cross reference the bearing, race & seal. turned out they used all the same parts. I put oil in the repaired wheel & also put in the other with the grease. yes I put hub oil mixed with the grease already in the hub. it gave me no problems for several years.
