How to properly unload a hopper and load a hopper
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by GrainHaulerFargo, Sep 21, 2024.
  1. GrainHaulerFargo
    GrainHaulerFargo Bobtail Member
    6
    8
    Oct 30, 2023
    So a while back I was considering to get into hopper bottom finally pulled the trigger just looking for any tips or pointers on how to load and unload hoppers .. should my tarps always be open when unloading ? Should my bags be dumped ? Any advice helps thanks from one owner op to another … any advice is welcome please post I’ve only
    beastr123 and broke down plumber Thank this.
  3. MacLean
    MacLean Road Train Member
    1,267
    3,715
    Sep 12, 2017
    Neither. Always leave your tarps closed unless you’re loading just in case rain sneaks up on you. A nice soft rubber hammer is good to have as well.
    Puppage, broke down plumber and TX2Day Thank this.
  4. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    opening tarp depends if you hopper is vented and how fast you are dumping. If no vents and dumping super fast yes open the tarp or risk sucking the tarp bows down.
    Dumping the bags is more of a personal preference. some guy do it just to get the hoppers closer to the ground and spill less. again maybe if dumping super fast dump your air but I've never seen a problem from not doing it
    Sons Hero, Speedy356, Oxbow and 2 others Thank this.
  5. TX2Day
    TX2Day Medium Load Member
    613
    4,096
    Apr 24, 2023
    Texas
    Open the tarps as previously mentioned. I 2nd the soft hammer to get anything stuck to the walls of the trailer unstuck.
    I also rigged a long nozzled, 6ft., air line that I would use to blow the material stuck to the trailer walls. Worked great and kept me out of the trailer. I also had a very long handled, home made, push broom. That way I could stand on my collapsible ladder and push the chicken meal out without having to get in it.
    On that note, you may find that some chicken meal will burn you, wear long-sleeved shirts and always carry a respirator for those places and in my case, some fertilizers. (Yes boots and long pants as well.)
    Get an airline inside your truck as well. The dust and dirt when you pull a hopper will amaze you.
    Good luck!
  6. broke down plumber
    2,562
    18,143
    Jan 25, 2024
  7. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
  8. Judge
    84,520
    Slow pit where you just crack doors open you can leave tarp closed.
    If you open all the way and empty quick, it’ll pull your tarp down/bend bows/rip tarp.
    If small pit don’t have to dump bags, big unload fast, dump them cause it’ll stretch them to max.
    Can dump truck bags too on those, saves bags.
    Some of what you’ll get into.
    Soybean meal i don’t usually dump bags, that when you get it moving the trailer will bounce, rock side/side and sometimes help start, you’ll get dusted out.
    25(2)+2 Thanks this.
  9. Judge
    84,520
    here’s rice hill loading and winters coming..
  10. wore out
    wore out Numbered Classic
    15,335
    185,100
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Load your slopes let the product roll down on the doors.
    Dflip, Isafarmboy, Sons Hero and 4 others Thank this.
  11. 201
    201 Road Train Member
    12,047
    24,589
    Apr 16, 2014
    high plains colorado
    Load it until it runs over the side,,:eek:, not really, but I never thought any hopper bottom paid very well, and why most DID load the wagon. 90-100K gross was not unusual. One never saw a hopper at a state scale, and a hopper could be on a back road harvesting, and were left alone, in the Badger anyways. Cops knew generally, they weren't going far, and may be their father-in-law, and let them be. Unloading too, I used to pick up in Hastings, Mn. ( Ardent Flour?) and the lines to unload stretched for blocks. I knew lots of farmers that hauled their own grain with worn out Werner Peterbilts, but I can't recall anyone actually doing that for the money. Good luck.
