How to prevent ice from forming on cascadia windshield wipers?
Discussion in 'Experienced Truckers' Advice' started by dextrdog, Nov 9, 2018.
  1. dextrdog
    dextrdog Light Load Member
    124
    65
    Feb 2, 2012
    Milwaukee, WI
    No matter the temp , today it’s 31 and snowing and my left wiper keeps forming ice on it preventing it from clearly wiping. What’s a good temp setting to prevent this? Never had this problem with other trucks....
    tscottme Thanks this.
  3. buddyd157
    buddyd157 Road Train Member
    13,564
    34,840
    May 25, 2017
    under a shade tree
    i cannot believe you did not have this problem with other trucks..it's ice, it gets everywhere.
    buy winter wiper blades, and coat the arm with WD 40, try not to get any on the rubber?
    coat the entire metal arm (from the connection at the transmission) with WD 40 as well, or any silicon sprays for that matter.
    some people also recommend pulling down the inside sun visor close to the windshield, to trap air up in there to help the window stay warmer, i never found that to work.
    JonJon78 and dextrdog Thank this.
  4. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    If there’s no road spray hitting your windshield try keeping it real cold inside so the snow bounces off your windshield, I used to wear a heavy sweatshirt and a sock cap while driving
    Lepton1 Thanks this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    If it’s close to the freezing point, lots of heat on the windshield.
    If it’s colder and your going down the highway, no heat on the windshield. The ice will evaporate on its own.
    Winter blades help. I found that the factory blades are too long 24-26”?) I went down to 20” blades , that helps the wiper cut through the snow better.
    Lepton1, Oxbow, whoopNride and 5 others Thank this.
  6. dextrdog
    124
    65
    Feb 2, 2012
    Milwaukee, WI
    Man I wish my blades were longer. I’m 6’4 and if it’s snowing or raining I have to sit low otherwise I can’t see
  7. buddyd157
    13,564
    34,840
    May 25, 2017
    under a shade tree
    but then, you get to use a taller shifter, and fingerless gloves, and dark mirrored sunglasses..>!!!!!
    Lepton1, 06driver, Oxbow and 6 others Thank this.
  8. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,994
    9,709
    Oct 18, 2010
    NW Indiana
    Welcome to Freightliner World of nice weather driving. Been battling this for 20 years in my Argosy, Century Class platform.
    And has been expressed, an industry wide issue.
    Smaller winter blades, bend the arm so more spring pressure is applied, as much heat as you can direct, except in dry snow conditions.
    Stop if needed and break the stuff off, pro active helps,soon as it appears the conditions are ripe, start the checklist.
    Lepton1 and dextrdog Thank this.
  9. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    The best way I've found is to never drive north of the I-10 in winter. Works like a charm. :cool:
  10. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    I use the winter RainX wiper fluid. Pretty good at melting the snow to a certain point. Around the negatives it’s smudges more than clears though.
  11. dextrdog
    124
    65
    Feb 2, 2012
    Milwaukee, WI
    Hell yea! Hahah
    buddyd157 Thanks this.
