How to plumb old style 13 speed splitter?
Discussion in 'Ask An Owner Operator' started by Bean Jr., Feb 25, 2018.
  1. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,697
    Mar 30, 2014
    I bought an old style shift knob, a4491, splitter knob. It has 4 ports on the bottom. There is a thread for the 3 position knob, How to change to an old style (A4487) shift knob
    I'm assuming that plumbing the range will be easy, but does anybody know how to plumb this one?
  3. wore out
    wore out Numbered Classic
    15,319
    184,961
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The old 3 line knobs used a different slave that's no longer available.
    If what your putting on is a 4 line it will plumb like your new style knob
    Art Vandelay, snowman_w900 and SAR Thank this.
  4. Bean Jr.
    5,467
    9,697
    Mar 30, 2014
  5. Bean Jr.
    5,467
    9,697
    Mar 30, 2014
    This is only the splitter. The range is s plunger. I have 4 lines going to the handle, but 2 are for the splitter and 2 are for the range.
    wore out Thanks this.
  6. wore out
    15,319
    184,961
    Jun 5, 2013
    Are your lines colored or not? I' fixing to have to step but can get it all typed by morning if you don't have the right answer by then
    Grubby Thanks this.
  7. MACK E-6
    48,113
    219,512
    Seems fairly self explanatory, I would think. Red line to the one marked “E”, blue to the one marked “S”, and the other ones may be determined by where you prefer your “split” vs direct.
    If it’s not that simple, then I’ll shut up now. :)
  8. Bean Jr.
    5,467
    9,697
    Mar 30, 2014
    The plunger is in the mail. That should be easy to hook up. Then hopefully it well work out with the other 2 lines. I'll report back after I've done it.
  9. wore out
    15,319
    184,961
    Jun 5, 2013
    It is really self explanatory. Main thing after you get your plunger working right is make sure air to the split is dead with plunger in low
    snowman_w900 and Bean Jr. Thank this.
  10. Bean Jr.
    5,467
    9,697
    Mar 30, 2014
    Sorry for the late update. I checked to see which were supply, and hooked them up to the plunger and splitter. Got it right the first time.
