How to not damage the clutch brake
Discussion in 'Questions From New Drivers' started by Labrador, Jun 19, 2024.
  1. Labrador
    Labrador Medium Load Member
    485
    536
    May 31, 2018
    Manual transmission. When you are rolling to a stop, truck in gear, if you have the clutch all the way in while still moving (and in gear), does this wear out the clutch brake?
    77fib77 and tscottme Thank this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    You should never have the pedal fully depressed while still moving. Only stopped.
    Yes it can and will damage the clutch brake. If you have an air or hydraulic assisted clutch linkage this is even more likely. Harder to do with manual linkage but still possible.
  4. tscottme
    tscottme Road Train Member
    Yes. NEVER PUSH CLUTCH PEDAL MORE THAN 1/2 WAY except when stopped. Use just enough cluth pedal travel to get into/out of gear.
    kylefitzy and ducnut Thank this.
  5. ducnut
    ducnut Road Train Member
    2,429
    7,211
    Dec 31, 2010
    SPI
    The only time you should use the clutch brake is going from sitting in neutral, clutch pedal out, to putting the transmission into gear. The clutch brake is used to stop the clutch disc and transmission input shaft from spinning, so you can select a gear.
    When sitting at stoplights, in a line, traffic, etc, always put the transmission in neutral and let out the clutch, to save wear on the throwout bearing.
    Be nice to your clutch and transmission components.
    Labrador and tscottme Thank this.
  6. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    it's is literally a brake. much like any other brake. it has friction material that wears with use.
    yes you will wear it out of break the tabs rendering it useless
    blairandgretchen and Labrador Thank this.
  7. Ridgeline
    22,103
    113,210
    Stop doing that.
    Unless you want to pay to properly replace it, which means money.
    Labrador Thanks this.
  8. Labrador
    485
    536
    May 31, 2018
    Oddly it was never mentioned in trucking school or any of my training for a couple of jobs.
    OLDSKOOLERnWV and ducnut Thank this.
  9. tscottme
    This isn't the last important detail nobody tells you in trucking.
    Opendeckin and ducnut Thank this.
  10. Labrador
    485
    536
    May 31, 2018
    lol
  11. Ridgeline
    22,103
    113,210
    Sorry if this hurts feelings but it is a real common sense thing.
