Not sure if this is the right thread BTW.
I'm going to be picking up at Maryland Core tomorrow out in Baltimore. They ship scrapped auto parts (transmissions, engine blocks, etc)...so heavy f**king ####. Since each of their totes on pallets weigh differently, how should I make sure that they load me properly so I can legally distribute the weight?
The last time I was there they loaded too much weight in the nose of the trailer (my drives were at 37000 lbs) and they jammed every pallet against each other so even by sliding my tandems all the forward didnt help me out. (Knowing it's illegal in Maryland to have your tandems all the way forward.)
How to make sure shipper loads you properly?
Discussion in 'Trucking Industry Regulations' started by HwyDragon, Apr 13, 2017.
Try to put the heaviest totes in the middle. If the weights arent marked, you'll just have to guess.
I've had that problem hauling Dal-Tile out of Texas. Ceramic tile is really heavy and the shippers have no idea how to place the pallets.Last edited: Apr 13, 2017
HwyDragon Thanks this. -
Not knowing how many totes you may pick up, and assuming the disparity between heaviest and lightest is not too great. An example of 19 totes might be
But that's the way I'd load 53 foot reefer suitable for California, but a dry van should not necessarily alter that configuration much. But if they all vary wildly and they are pre-weighed and tagged, I'd take the 8 heaviest ones and put 4 in first, and the remaining 4 in last, trying to keep the two lots about the same combined weight-wiseLast edited: Apr 13, 2017
With scrap, even toted scrap every load is going to be different obviously. If they don't have scales on-site you are going to be screwed. Just keep scaling and taking it back to get it legal. After a few weeks you'll get a feel of which totes will need to be where.
Imagine having "no weight" towards the rear of the trailer. A 3 foot tandem slide will probably have negligible effect on the drive weight because there is insufficient weight behind the trailer "pivot point" to lighten the nose [if needed]
Plus from an engineering standpoint, I'd prefer not to test the integrity of the trailer support capacity by placing upwards of 2/3 of a heavy load inside the middle third of the trailer span. Especially given the way many bridge approaches and road dips are today that can cause severe bucking and testing of engineering limits of light van trailers.
Flatbeds are designed with this in mind, highcube 53 foot dry vans, not so much.Last edited: Apr 13, 2017
This is a crapshoot. 1 st find out how pallet sized totes there are in the shipment. Segregate them mentally heaviest to lightest. I would put 4 of the heaviest ones in the nose, spread out the lighter ones in the middle and the 4 remaining heavy ones right over the tandems. I wouldn't load any more than 48' of trailer, leaving 5' empty at the tail if it is a 53' trl. Tandems would wind up about 10' from the end of the trailer. Warn the shipper that if anything is out of balance or over, he will have to reload the whole thing. That might get their attention.
