How to know if you need new air dryer or just air dryer cartridge?
Discussion in 'Experienced Truckers' Advice' started by Kenworth6969, Aug 21, 2021.
  1. Kenworth6969
    2,725
    7,831
    Jul 3, 2020
    Any signs it could be one or the other?
  3. Ridgeline
    22,103
    113,210
    Why are you asking?
  4. Kenworth6969
    2,725
    7,831
    Jul 3, 2020
    Got a new older truck and lots of water building up in air tank.
    I even got sprayed with water coming of transmission when I flipped the splitter :eek:
    Rideandrepair Thanks this.
  5. skallagrime
    skallagrime Road Train Member
    3,836
    9,879
    Apr 10, 2012
    Indiana
  6. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    It's a maintenance item. Change it yearly before winter. No need to check it, just change it
  7. AModelCat
    154,278
    If its a few years old I'd just replace the whole unit. After that I'd just stick a new cartridge on it every fall from then on.
    ibcalm19 and Rideandrepair Thank this.
  8. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    Mines doing the same. Blows water from blow gun. That’s definitely a sign. AD9 are cheap enough. I agree with everything already said. I just saw them at Freightliner in Monroeville Ohio for $139. I should have just bought one.
  9. Ridgeline
    22,103
    113,210
    Well you answered your own question.
    seriously they should he changed every three years unless you have issues with water or running in high humidity areas.
  10. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    It all depends on what year the truck is and what type of air dryer it has on it now? The old type the filter just unbolts and is replaced, the newer type the filters unscrew and have diff. types of medal on the housing and filter and can be like getting a bears jaw apart, and have air lines that control ride hi. of truck and air ride cab and up to 4 other things, and its best to try too get filter off 1st then replace it with a name brand filter, If you can't take it off, pull the hole thing off the truck leaving all hardware in place on frame of truck, and bring the ck. book with you to parts store and be sure to buy a new one not a rebuilt unit air dryer ###.
