How to jump this starter in picture
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 4noReason, Dec 30, 2024.
  1. 4noReason
    4noReason Road Train Member
    2,391
    750
    Nov 29, 2012
    Hi all
    As you can see in this pic. This is a starter with 3 bolts showing. If i were to jump starter because solenoid wire broke. Which 2 bolts do I need to touch together with a screw driver or vice grips to get it going in emergency. thanks 2016 columbia
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,941
    Oct 31, 2023
    The two next to each other at the solenoid.
    Rideandrepair and 4noReason Thank this.
  4. 4noReason
    2,391
    750
    Nov 29, 2012
    thx a lot
    Rideandrepair Thanks this.
  5. 4noReason
    2,391
    750
    Nov 29, 2012
    wait. yes I know that. but what if selenoid wire broken?
  6. Iamoverit
    2,159
    4,941
    Oct 31, 2023
    You're bypassing the solenoid. Read up how one works. You're just activating it manually instead of using the switch/exciter wire. Be ready for a good fireworks show and make sure you're not grounded.
  7. 201
    201 Road Train Member
    12,620
    25,902
    Apr 16, 2014
    high plains colorado
    Make sure it's in neutral. I knew of a farmer that jumped the starter and got ran over.
    4noReason, Rideandrepair and Iamoverit Thank this.
  8. rbrtwbstr
    rbrtwbstr Road Train Member
    3,386
    7,836
    Jul 11, 2012
    in the bush somewhere
    Yeah and don't use anything flammable to clean the posts before touching anything to it. It tends to catch fire :D
    I used ether on a farm tractor starter and once it sparked the dang thing caught fire.
    4noReason and Rideandrepair Thank this.
