How to jack up a trailer when landing gear fails- Belly Dump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by drew724, Jan 29, 2015.
  1. drew724
    drew724 Bobtail Member
    32
    Mar 28, 2013
    Well, the landing gear (on this belly dump they are just legs that slide up and down) was set but the guy forgot to put the pin lock on the belly gates which the legs are attached to. So in the mud, the legs go apart and the belly gate opens up and down she goes. Resting on a partially opened gate. Too low even for a tractor with emptied air bags to get underneath.
    Trying to figure out how to jack it up with jacks instead of having to get someone out there with a back ho or fork left to lift it up. Any ideas??
  3. 201
    201 Road Train Member
    12,047
    24,586
    Apr 16, 2014
    high plains colorado
    Hi drew, on tankers, we called those "peg legs". Is the trailer empty? Regardless, if you can't get under it, a forklift is the only way if it's empty. If it's loaded, you may need a wrecker, which isn't cheap. I'd find out who dropped it, and slap them up side the head.:biggrin_25513:
    cnsper Thanks this.
  4. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    We were stuffing logs into a container one day and the landing gears collapsed. Took an entire day with a pair of 20 ton bottle jacks and a whole bunch of wood blocks...jack it up, brace it, jack it up some more...until we could get back under it. Would have been cheaper in the long run if the boss had listened to me and just got a wrecker out there to lift it up, but what did I know? Anyway, with an empty trailer it would be MUCH easier, as any loader/backhoe/forklift ought to be able to pick it up. If you do resort to jacking, it'll be easier on the arms not having +30K in the nose you're trying to lift. Good luck.
  5. crzyjarmans
    crzyjarmans Road Train Member
    3,310
    2,427
    Jun 9, 2010
    Home
    "semi" retired is correct, that's about your only option
  6. crzyjarmans
    3,310
    2,427
    Jun 9, 2010
    Home
    is there anything over trailer? something durable? have a long chain or sturdy rope? attach one end to trailer, throw whats over head and the other end to tractor, but highly unlikely there something there
  7. wore out
    wore out Numbered Classic
    15,319
    184,959
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Cheaper or easier on you
  8. drew724
    32
    Mar 28, 2013
    Yes the trailer is empty. Because of the mud, I guess the peg legs spread apart since the idiot didnt lock the gates before unhooking the trailer. Here is a pic of where it sits before it "sank". View attachment 77910
  9. 201
    12,047
    24,586
    Apr 16, 2014
    Hi drew, those attachment pictures never work, ( my biggest gripe here)but I have an idea what happened. If I ever dropped a trailer and I knew it was soft, I'd try and find some wood, or a plank to put under the legs.
    dog-c Thanks this.
  10. BROKENSPROKET
    BROKENSPROKET Medium Load Member
    675
    172
    Jan 22, 2011
    Wisconsin
    I would love to see a picture of that.
  11. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Well, by the time they paid the fuel bill for the truck to run 2 hours South to HQ where the jacks were, then 2 hours back up to the log yard...plus the wages for the 2 of us out there messing around with the jacks all day instead of loading containers, which may have incurred charges for the extra day we had them (too long ago for me to remember)...
    Yup. Would have been much cheaper in the long run to have a wrecker come out at $200-300/hour for the 30 minutes or so that it would've taken to raise the boom, wrap a strap around it, and winch it up.
    ...and easier on our arms, too.
