How to hold (fuel pump) gear to tighten nut?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Apr 20, 2020.
Page 2 of 3
tj379, HoneyBadger67, little cat 500 and 1 other person Thank this.
Stick it in a vice, jam a chisel/prybar or somethin' between the gear's teeth and bench on the side that locks the gear in place while you torque the nut.
Same deal like if you're wrenching on a vehicle and need to stop something from spinning.PE_T Thanks this. -
Another option I found online is using a flywheel stopper/locking tool.
Rideandrepair Thanks this. -
Well what did you end up doing? Seems a vice with wooden blocks, would be the best way. Wood won’t damage teeth.
PE_T Thanks this. -
I ordered a fuel priming pump that I will need after doing this job. There are cheaper alternatives, but after wasting a couple hours deciding on what to do, I just ordered the one recommended by Detroit (J-47912, part number). It’s expensive, but it’s ready to use. Out of all the cheaper alternatives out there, the better one is to buy a stainless steel sprayer, the compucheck adapter, and possibly some other adapters and a long hose. This one would save you about $125 versus the Detroit recommendation.
I bought a plastic sprayer from Walmart that would do the same job as that expensive stainless on for 15$ fyi
PE_T and Rideandrepair Thank this. -
Compuchek, that’s it. I couldn’t remember what they called it. I used a mini air compressor, hooked to vent tube on fuel tank, crimped off the other side vent. It took a while, but worked. I put 20 lbs. way too much. A few lbs is all that’s needed.
PE_T Thanks this. -
So the method I ended up using was wood and napkins to protect the teeth and my trailer landing gear as a vise. I was getting a little worried about the amount of pressure I was putting on it, but it worked.
Just so everyone knows, changing the fuel pump on a DD15 is a nightmare. This has been the most difficult and time-consuming repair I’ve done. I’m surprised everything came out well, but I took my time to get it done right, and read and reread and watched several videos.Dave_in_AZ Thanks this.
Page 2 of 3
