How to get off the do not load list at Tql?
Discussion in 'Freight Broker Forum' started by Kyefremova, May 2, 2022.
  1. Kyefremova
    Kyefremova Bobtail Member
    7
    May 2, 2022
    If a tql broker decides to drop a company what does that mean how does this work ? Does this mean your company can no longer work with tql or just that broker ?
  3. bad-luck
    bad-luck Road Train Member
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    It means you were put on the do not load list. And yes TQL will no longer load your company.
  4. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
  5. Kyefremova
    7
    May 2, 2022
    Great how long is that for or is that permanent
  6. scott180
    scott180 Road Train Member
    1,213
    4,203
    Dec 10, 2012
    Tooele, UT
    So, what happened?
  7. bad-luck
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    Usually its permanent. You would have to get them to reverse it.
  8. Kyefremova
    7
    May 2, 2022
    How would I do that
  9. Kyefremova
    7
    May 2, 2022
    Truck broke down for days got fixed died again and again and again and the load is like 4 days late and it’s just so much ########
    Lite bug and Bret1984 Thank this.
  10. bad-luck
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    You would have to speak to the agent that you booked the load through.
    I read it were you posted that your truck broke down. Did you communicate with the broker when this happened?
    KB3MMX Thanks this.
  11. Kyefremova
    7
    May 2, 2022
    Well that’s the problem the driver kept saying I’ll get it tmw I’ll get it the next day and the next day comes he still didn’t pick up so he was just giving them the run around thinking the truck will get fixed and he would pick up then the truck would break down again
    KB3MMX Thanks this.
