how to get into heavy hauling work
Discussion in 'Ask An Owner Operator' started by Tyler Reiner, Feb 28, 2023.
  1. Tyler Reiner
    Tyler Reiner Bobtail Member
    I just have a simple question that is probably pretty complicated, how would a owner operator get into heavy hauling. ideally local or home every other day. I've looked at hauling combines and such from factories to dealers and also thought of finding excavation company's that just need there equipment moved from one work site to another.
    are there certain company's that find heavy hauling loads for owner operators? or is there a decent amount of heavy hauling loads just on DAT or Truckstop?
  3. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    Find companies near you that do crane and rigging work or road construction companies that need equipment moved. I'm not sure how Buchanon is to work for, or if you live in their hiring area, but I've run a few loads from their brokerage and have no complaints.
    I don't haul heavy, but that's where I would probably start.
  4. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    It depends what you are looking to do.
    If you have a regular tractor and you want to start out with a 35-ton trailer then you need to go around as has been said to the construction companies, the crane companies, the rental companies, etc near you look for work that way. I actually had a quarry approach me about hauling their flatbeds and low beds so perhaps that's another option.
    If you really want to get into heavy haul, meaning oversize loads, you're going to have to have a heavy haul truck.
    Then you need to lease on to a company that will accept you without experience. I don't know if that's a big deal or not, but you do have to be able to safely and correctly load and chain/ strap down according to dot standards.
    When you get into the real heavy Haul you need to be leased on somewhere as I said that will guide you through that because it's a whole entirely different world and the guys that do that are experts in a thousand different ways than regular truck drivers are not.
    I don't mean that they're any better but they have a different skill set. Hopefully they know how to drive pulling 120,000 pounds behind them and a load that is oversized that if they're not careful they can wipe out a whole city street of cars parked there. And if they make one wrong turn that's off the permit route, that will cost thousands of dollars in fines.
    And then on top of that the states have different regulations regarding weights and axle limits and length and I assume oversized permits and overhang and all the other myriad of things that you have to understand for each single state that you will operate in.
    It would be much easier to stay loaded and keep rolling if you were leased onto a Heavy Haul company. I don't know about how often the home time would be though.
    Maybe if you contacted a Heavy Haul company they could lease you on but not for the supergiant colossal loads maybe more for Flatbed loads or small oversized loads to get you started until you can get an actual Heavy Haul set up?
    Maybe there's a local Heavy Haul place near you?
  5. OscarGoldman
    OscarGoldman Light Load Member
    264
    534
    May 9, 2022
  6. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,601
    Nov 11, 2020
    First you need the right truck, not an otr truck. Second you need the market for it. When I lived in NY I could find constant freight in and out of port areas.
    3rd you need a trailer. So about half a mil in equipment, and you can starve your way thru 2023.
  7. OLDSKOOLERnWV
    17,804
    268,358
    And a lot of it….
