How to find backhauls?
Discussion in 'Ask An Owner Operator' started by fleetfox, Jul 15, 2016.
  1. fleetfox
    fleetfox Bobtail Member
    4
    Newbie here:
    What are some strategies y'all use to flesh out your loads. Seems whenever I am able to find loads TO a location, I'm stuck hauling nothing back. How were you people able to overcome it? Not important for me to go directly back home either, by the way.
    Considering just finding a consistent route and then spending some time trying to meet with every single agent in that and surrounding areas. Not afraid to work for it.
  3. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    Rule one, don't call it a backhaul. The second a broker knows that, the lower the rate
  4. Showtime89
    Showtime89 Light Load Member
    105
    106
    Feb 25, 2016
    ^^^ yup no such thing as back haul.... Just a haul from where your sitting at to the next location. IF they hear you sya backhaul or know your trying to get home rate about cut in half.
    misterG and scottlav46 Thank this.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Easy to find backhauls. You don't want any of those though.
  6. ramblingman
    ramblingman Road Train Member
    1,152
    1,115
    Jan 12, 2014
    FFS... Their is nothing wrong with back hauls. They are a result of the supply and demand nature of our economy. If you know what your doing you will use them to raise your running mile. If you have a ton of flatbed loads moving out of Chicago and not enough trucks you may get say 3 dollars per mile going to Washington on a 2000 mile load. Then you load up some Kaiser Aluminum for 1.50 after say bouncing 200 miles and go back to Chicago with another 2000 mile load.
    You just ran 4200 miles and grossed 9,000 dollars presumably in a week.
    The running mile for the week comes out to 2.14
    Your costs as an independent with truck and trailer + own authority should not exceed 1.30.
    So you just took home 84 cents per mile for the week and you hauled a gasp *Backhaul*
    spyder7723 Thanks this.
  7. wore out
    wore out Numbered Classic
    15,319
    184,958
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Not being an ###, simply stating a fact. This is a question that should a been asked and answered before you put your name on the door.
    akfisher, exhausted379, cnsper and 5 others Thank this.
  8. crappedouttrucker
    crappedouttrucker Light Load Member
    100
    74
    Jul 3, 2016
    find your next load before you take off with current load. in trucking: learn to plan a few days ahead. never take a load with having away out of where your going.
    Hurst Thanks this.
  9. crappedouttrucker
    100
    74
    Jul 3, 2016
    good point! people don't think about that before starting a trucking business.
  10. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I just follow the money. Make sure its going to a decent lane. Then pre-jump on the next best rate with miles. Often I'll pre-book 2 - 3 loads out. I get back home when I get back home.
    Hurst
    scottlav46 Thanks this.
  11. Not_Here_Long
    Not_Here_Long Medium Load Member
    523
    409
    Sep 7, 2015
    Make enough money out bound to bounce home empty.
    the word back haul is like holding a 'will work for free" sign.
    Terry270 and scottlav46 Thank this.
