How to fill out log for local runs
Discussion in 'Trucking Industry Regulations' started by darwinsti, May 27, 2012.
  1. darwinsti
    darwinsti Bobtail Member
    edenton, nc
    Trying to make sure im doing the right thing with my log book. If i am doing local runs within 100 air miles can I log it legally as off duty local run? Also, while waiting for the loads to be loaded/unloaded, is it right to put it as off duty or should it show sleeper birth? Im asking this question for my husband though he is half asleep telling me what to write since he got in an hour ago from a 3 day florida/georgia/sc/nc haul, so forgive me if i don't quite ask the questions right...im trying.
    Thanks in advance for any help.:biggrin_25518:
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    It depends as a 100 mile driver....
    If you work 12 hours or less a day you are exempt from 395.8. Which means a time card is satisfactory. Then if you log on RODS instead of a time card you need driver identification, the date, the time the driver began work, the time the driver ended work, and the total hours on duty to satisfy the DOT.
    I would log like an OTR driver but you can leave out miles, company, BOL/shipper/commodity and recap if it's on your logs.
    If they have you working 14 hour days, then I would log just like an OTR driver as it's required, regardless of the 100 mile rule.
    Usually when a company requires a local guy to log is because they have OTR drivers also or ones that go outside the circle. That case I would discuss it with your log/safety person and ask them how they want it done. Regardless of the rules they might want you to log like an OTR driver to make their job easier.
  4. Empyrean
    Empyrean Bobtail Member
    30
    4
    Jun 3, 2012
    Western Washington
    I run local. Usually stay within 100 miles of my home base. But, I log as OTR as per my company. It was annoying at first but then realized it made my life a lot easier, since now, when I DO have to go outside of 100 mile radius, I don't have to think or worry about it. It's covered. Good habit to be in anyways as far as I see it.
  5. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    Operating under the local exception (under 100 mile radius, return and go off the clock within 12 hours) just means you do not have to carry a log book for that day. It is NOT off-duty. Your work hours still count for the 11/14/60/70 rules.
    You can only log sleeper berth when your carcass is actually in the sleeper.
    "attending a commercial motor vehicle being loaded or unloaded, remaining in readiness to operate the commercial motor vehicle" is on-duty time. (395.2 definition of on-duty time)
  6. Empyrean
    30
    4
    Jun 3, 2012
    Western Washington
    I know that doesn't answer your question though. Seems CondoCruiser knows the reg's better than I.
