How to dump a quarter frame end dump ????
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by KwBulk18, Jun 5, 2019.
  1. KwBulk18
    KwBulk18 Light Load Member
    72
    17
    Jun 4, 2019
    Hey so I’ve seen threads on this about how to dump frameless steps and process ect ? With a quarter frame do I set trailer brakes ?? Or just keep foot on break ?? Do I set tractor break ? Do I dump bags on trailer and tractor ?? Ect some vets please explain me and my buddy are curious thanks !!
  3. stuckinthemud
    stuckinthemud Medium Load Member
    620
    3,063
    Oct 20, 2013
    I usually pulled trolley brake let trailer pull the tractor back towards pile where you dumping , so the trailer would remain stationary. The last tractor I owned did not have an air suspension dump switch, never had any problem with air bags
  4. 201
    201 Road Train Member
    12,052
    24,606
    Apr 16, 2014
    high plains colorado
    I pulled a frame dump trailer for years, never had a problem, but I've seen my share of frameless go over. Not sure what this driver did wrong. Material hung up, maybe?
  5. BigBob410
    BigBob410 Road Train Member
    5,665
    74,100
    Feb 2, 2016
    Beirut on the Bay, MD.
    Did the load push on the trailer? Looked like the trailer lunged forward and bound up.
    Humblepie Thanks this.
  6. Itsbrokeagain
    Itsbrokeagain Light Load Member
    155
    199
    May 31, 2019
    Didn't look like anything dumped. Did he forget to open the gate?
  7. KwBulk18
    72
    17
    Jun 4, 2019
    That’s what it looked like
  8. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    dump air bags,set trailer brake release tractor brake.Dont put foot on pedal brake and of course make sure you open tailgate
    KwBulk18 Thanks this.
  9. wore out
    wore out Numbered Classic
    15,340
    185,249
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Thing about a frameless is the break away bolts save the truck from going over 25 percent of time or so. A full frame will take it every time
    BigBob410 and Humblepie Thank this.
  10. 201
    12,052
    24,606
    Apr 16, 2014
    That's true, except, I don't remember a frame type going over, although, I'm sure they have. I've been on spread jobs with a frame dump, and was no place for a frameless. Aside from weight savings, I don't see the advantage to a frameless. Will that extra material you can haul ever pay for an upset? I like heavy duty trucks, ( Mack and a frame dump, couldn't kill either one) and a frameless always seemed like a wimpy dump trailer to me.
  11. wore out
    15,340
    185,249
    Jun 5, 2013
    I have seen full frames go over quite a bit. Hauling shale in for fill. Think its solid and start up when you see it ain't is after the ground gives away. Used 1/4 frames (both axles stay on ground) dumping into lay down machines and seen them lay over on the shoulder.
    A frameless will usually show you a sign when hauling fill but not always
    BigBob410, Humblepie and 201 Thank this.
