Hey skateboarders, how do you guys dry your tarps. I ve been dealing with wet tarps alot and using alot of plastic under wet tarps just to not get claims . I understand when you load and unload inside. you can keep them dry enough but untarping in rain on wet pavement gets them wet on bothe sides . I usually bring them home and lay them open in heated garage but dont have that luxury on road. Any tips and tricks will be greatly appreciated.![]()
How to dry tarps
Discussion in 'Flatbed Trucking Forum' started by kay_ray, Nov 19, 2024.
Maybe it's a bad attitude, but I've never worried about it. Anything that absolutely can't have any moisture on it should already be covered in plastic or crated. If anyone ever commented about wet tarps, I'd just ask them to direct me to their tarp drying station.
If the load is required to be dry, shipper usually has to supply the plastic to go under the tarp, to avoid possible moisture issues....but inherently, there is the possiblity of condensation even when tarped, so it's pretty much up to the shipper how much care they want to take to prepare the load.
I had an alloy load that had to be completely moisture free, or else it would start oxidizing, swell up and not fit in the machinery that was supposed to make parts out of it. That was a pain in the butt load, as it was overweight on the first loading, and I had to have them reload it, so the plastic and tarping was a double job, however, they supplied the plastic...I just had to supply the labor. Most other loads, unless one right after another, wet tarps weren't much of a problem as they tend to dry quick in warm weather, but will be wetter in cold weather, but the tarp is mostly meant to protect from salt or excessive moisture, not a little.
This load was plastic covered, strapped, plastic covered again, and then tarped. If you look near the plastic on the ground, there is a little moisture that came off of it, because the tarp was unable to keep all the water out via either condensation of plastic over plastic or maybe a leak in the tarp or driving rain coming in at the overlap, the sides, or the seams.
Sirscrapntruckalot, blairandgretchen, Kyle G. and 4 others Thank this. -
cke, TX2Day, D.Tibbitt and 1 other person Thank this.
Kyle G., cke, TX2Day and 1 other person Thank this.
I'm not sure what else a guy could do other than lay em out in the sun. I wouldn't worry to much about it.
Kyle G., cke, bryan21384 and 4 others Thank this. -
CAXPT, cke, TX2Day and 1 other person Thank this.
Most of these shippers are cheap and won't provide plastic but claim the product cannot get wet... LOL... Oh yeah, and go tarp outside while it's raining...
The only shippers I can really think of that actually provide plastic is tubing places, Bull Moose, Independence tube, etc etcCAXPT, D.Tibbitt, cke and 1 other person Thank this. -
Maybe lay it out and wipe it down with Rain-X? Lol I'm not sure. When I hauled flatbed, I always just laid it out in the grass on a sunny day. If you can store it in a tarp box that'll work. Some trailers have that box in between the spreads on the trailer. I've seen other trucks that have a compartment for tarps on top of the headache rack. That'll at least keep it out of the elements.
D.Tibbitt Thanks this.
