How to drop trailer air bags- dry van
Discussion in 'Trucks [ Eighteen Wheelers ]' started by firecatf7333, Dec 19, 2022.
  1. firecatf7333
    firecatf7333 Light Load Member
    175
    59
    Oct 28, 2012
    Is it possible to let the air out of the bags on a standard dry van trailer to help lower the rear loading height?
  3. mitrucker
    mitrucker Road Train Member
    5,140
    8,804
    Dec 15, 2010
    Lapeer, MI
    Yes. There are various ways to achieve this. Some are plumbed to let the air out when the brakes are set. Some have a manually operated valve to release the air.
  4. bad-luck
    bad-luck Road Train Member
    3,245
    5,943
    Nov 16, 2013
    Baltimore, Maryland
    Yes, you need to have a dump valve on the trailer.
  5. firecatf7333
    175
    59
    Oct 28, 2012
    Do most have a dump valve standard already on the trailers from factory
  6. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    You can also disconnect the rod where it connects to the arm on the valve. Then move the arm downwards to dump the air. When you're done, you connect the rod to the arm and it should return to the original height.
    lester Thanks this.
  7. Professor No-Name
    Professor No-Name Road Train Member
    3,907
    7,492
    Nov 26, 2016
    If your trailer has dock leveler arms don't worry about it. Just back into the dock an set your trailer brakes. The bags should release some air an the trailer should rest down on the levelers. We pull newer utility reefers an dry vans an that's all i ever do. Have never had a problem with the trailer being too high for loading and i always slide the tandems to the rear when live loading or unloading. Also the constant bounce of the forklift driving on an off will force air out. If ya notice once you're loaded or empty you normally have to build up air pressure that's been lost in the process.
    RubyEagle and Brettj3876 Thank this.
  8. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Same with Hyundai vans
