Got a 2014 Kenworth T680. How do i drain the DEF tank on this? Wanna drain it and replace the fluid in it....
How to Drain DEF tank?
Discussion in 'Kenworth Forum' started by TruckerPete1990, Apr 25, 2023.
Depends on the tank used but some have a drain plug on the bottom, others its just easier to use a siphon and drain it into a bucket then flush with known good def.
TruckerPete1990 and JB7 Thank this. -
https://www.thetruckersreport.com/truckingindustry...
WebAug 12, 2021 · I thought I would share how I drained my
If no drain plug:
1 - siphon
2 - pump
3 - remove tank
4 - leaf blower (see link)TruckerPete1990 Thanks this. -
I'm not sure a sipon will work because this def been sitting inside my tank since 2019. Hoping it's not all crusty
I bought a little 12 volt electric pump on Amazon for like $30 that will suck semi thick paint out of the bottom of old sprayers. Does a good job and if you clean the pump good afterwards you can use it for other fluids as well. Does not plug up easily.
I'd just take it off and dump it.
TruckerPete1990, lester, God prefers Diesels and 1 other person Thank this. -
You will never get all the old DEF out without removing the tank. Take it off complete and wash it out and dry completely. While you’re in there, replace the sock/ filter on the pickup pipe.
TruckerPete1990, AModelCat and lester Thank this. -
Thanks guys I'll probably just pull it off wanna clean the frame anyway.
