I have an automatic truck with an allison transmission that automatically selects neutral when the parking brake is engaged. How do I perform a tug test with this transmission? It will not select a gear when parking brake is applied
How to do a tug test in an automatic allison transmission.
Discussion in 'Trucking Schools and CDL Training Forum' started by TruckerHart, Nov 3, 2021.
Page 1 of 3
Why are you setting the tractor parking brake to do a tug test? All that tells you the tractor brakes are holding and nothing else.
To tug test, you hook up, look to make sure the jaws are engaged, then pull forward to test if the jaws are fully closed and locked. -
truckdriver31 Thanks this.
From what I understand they are testing me not the truck but the brake test seems like it has these several distinct parts.
truckdriver31 Thanks this. -
following
Tug test is to test that the 5th wheel is properly engaged and locked, and has absolutely nothing to do with checking tractor parking brakes.
Wow.firemedic2816, Last Call, Hatt91 and 8 others Thank this. -
Last Call, Hatt91, God prefers Diesels and 3 others Thank this.
Page 1 of 3
