how to dispute an inspection report
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by DLJ, Mar 6, 2020.
  1. DLJ
    DLJ Light Load Member
    200
    49
    Apr 16, 2017
    basically one of my drivers was stopped , manual log book was correct except city names written on log b. where he stop , report was full of OOS and citation up to almot 2k $ , it was bs from the officer ,.any ways to make a report or do i need to get a lawyer to dispute it
  3. theSoz
    theSoz Light Load Member
    161
    385
    Jan 24, 2020
    How the hell do you get the cities wrong? Driver didn't know where he was??
    Pamela1990 and magoo68 Thank this.
  4. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    You can log it correctly all day long, but if you don't accurately annotate the geographical location of your stopping points then it is a violation (manner and form/falsification).
    Running paper, you have to be more than vigilant because they're going to look harder.
    You can DataQ it yourself once the system updates in the database. (Usually a month or so)
    If the driver received citations, you'll stand the best chance of DataQ success if those citations are DISMISSED in court.
    There is where the attorney will be helpful.
  5. Brandt
    Brandt Road Train Member
    4,402
    5,933
    Sep 17, 2012
    How does one get the cities names wrong and 2k. Did he put like Los Angeles when he was in Compton or was it Seattle and just s mistake we was off by 1,200 miles. Ha ha That's a simple fix get them ELDs problem solved. You can add up your hours wrong on paper and that a violation.
    Pamela1990 Thanks this.
  6. Moose1958
    Moose1958 Road Train Member
    15,088
    33,170
    Dec 17, 2010
    Williesburg, Virignia
    A DOT officer is not supposed to place a driver OOS for a "form and manner" violation of 395 without giving the driver a chance to fix the log first. This is right out of 395.13 (b) (3). I can only imagine this driver has a serious problem with how to properly log. However, if that DOT officer was presented with a log with any mistakes on it, that DOC officer in most cases will make a case. Each day can be a separate case too. I recommend log training for the driver and you might want to consider hiring an attorney for the court case.
    Edited: Once that part 350 inspection data is submitted to the feds it's going to almost take an act of Congress to remove it. Especially if it is right. Even if you get the court case dismissed good luck with that part.
  7. DUNE-T
    DUNE-T Road Train Member
    6,873
    16,584
    May 10, 2015
    Detroit, MI
    My driver received a speeding ticket in MI, went to court, officer did not show up and ticket was dismissed.
    I just requested a Dataq review and after my inquiry was submitted, it said that request went to MI state police. So will they be the ones who make a decision?
    Curious how it will turn out, never used the DataQ before
  8. kee1227
    kee1227 Bobtail Member
    32
    11
    Dec 5, 2012
    Hello, did you ever get it removed? If so can you share how? Thanks
  9. DUNE-T
    6,873
    16,584
    May 10, 2015
    Detroit, MI
    Yes, because local court dismissed the speeding ticket, DataQ was required to remove the violation from my company's record. Everything worked out good
  10. 11akash
    11akash Bobtail Member
    12
    5
    Dec 11, 2021
    Its usually tough but you can dispute it with DataQ but best bet that you have everything you need to back up why the officer was wrong.
  11. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,715
    Nov 7, 2021
    B.C. Canada
    I still want to know how the driver didn't know what city he was in.
    If I was an officer, and a driver didn't know where they were, I would be alcohol and drug testing them.
