How to disable truck speed governor on a 2009 Freightliner Columbia
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ichudov, Oct 14, 2017.
  1. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    My 2009 Freightliner Columbia has a governor that limits it to 66 MPH. This is how I bought it, it was owned by Praxair. Anyway, is there some way to disable this governor or at least increase it to 70 MPH?
    I own the truck and the company and so any such change is completely authorized.
    Thanks
  3. fuller
    fuller Light Load Member
    203
    295
    Nov 21, 2010
    Canada
    The shop can set all parameters for you, if you are the owner.
    Bean Jr., Tb0n3 and ichudov Thank this.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    You need to find someone with the computer that can go into the ECM and re-set the parameters
    ichudov Thanks this.
  5. fuller
    203
    295
    Nov 21, 2010
    Canada
    When I had my N14 computer replaced, they just assumed that I wanted O/O parameters, which I did.
    I can post here a standard O/O parameter setting, which does NOT include speed control.
  6. ichudov
    742
    641
    Mar 14, 2012
    Berkeley, IL
    So, pretty much, I just need to go to a dealer, right?
  7. fuller
    203
    295
    Nov 21, 2010
    Canada
    Yes. If you are the owner of the truck, you can set the parameters as you wish.
  8. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Not necessarily, you can go to a tuner that will probably charge less.
    Bean Jr. Thanks this.
  9. fuller
    203
    295
    Nov 21, 2010
    Canada
    Just ask for Owner/Operator specs.
  10. fuller
    203
    295
    Nov 21, 2010
    Canada
    It shouldn't cost much at all.
  11. 201
    201 Road Train Member
    12,047
    24,587
    Apr 16, 2014
    high plains colorado
    Someone told me once, if you floor and release the accelerator pedal 3 times fast, it temporarily over rides the governor for passing. Anybody ever try that?
    BoxCarKidd Thanks this.
