How to "dial in" a CB?
Discussion in 'CB Radio Forum' started by skinnytrucker79, Jul 21, 2013.
  1. skinnytrucker79
    skinnytrucker79 Light Load Member
    142
    1,601
    Jul 21, 2013
    Wisconsin
    First thing first. New to the forum here.
    Ok I am not new to trucking but the one problem I always have is for the life of me I can't ever figure out how to dial in a CB correctly. I recently got hired on to a new company so I have been slip seating till I get my own tractor. The CB in the truck is a Cobra. Not sure of the model, the company I work for now I drive regional, before it was local so I never bothered with a CB even if the truck had one. I look at all the dials now and scratch my head. I have the Squelch dial all the way back (counter clockwise) . Range sucks, I'm sure that is the antenna and maybe a old radio but for now having the basics down on a good setting is a good place to start. Thanks for the help. Be safe out there
  3. Ridgeline
    22,114
    113,317
    I don't know what you mean, you just turn it on and select a channel adjust the volume.
    Being old has zero to do with it, there isn't much technology change in CB design in the last 30 years other than component selection and yahoo features. Range is limited and should be because it is only supposed to be 4 watts going out to the antenna and it is a CB with everyone and their brother/sister screaming on it.
    There is a misconception about the squelch, I wish they wouldn't put it on the radio but they do so turn it so it makes a sound and keep turning it till it stops.
    RF gain which a lot of radios have, turn that the opposite way of the squelch, usually it is setup that way.
    The antenna may be a problem, it should be checked out by someone who knows what they are doing with the right tools.
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    If your having range issues...It's most likely the antenna's fault or where it's mounted...or both.
    Best antenna's are going to be ones taller than 6'...Best place to have it mounted is usually the roof, but that maybe impossible on a Big Rig, so next best place is either behind the cab or on the mirror bracket.
    If your using a 2' or 3' antenna, there's not going to be much you can do as for as range go's.
  5. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    What JJD said is right. The antenna is what makes or breaks the radio. CB's, in order to get the correct range, require a 9 ft tall antenna, believe it or not. Those little 2, 3 and 4 ft antennas on a CB are garbage. Oh sure you "might" talk 4 miles....if you're lucky. It's like trying to breathe thru a straw. The Wilson 2k is a good antenna, not as good as a 102 whip but about the best you can get on a semi.
    Of course a high SWR also plays a role in your range.
    Set the squelch so the radio stops hissing. If it hisses some more, add a little more squelch. All you're doing is setting the threshold for a signal to get thru.
  6. Ridgeline
    22,114
    113,317
    A good 5 ft antenna will work just as well as anything else.
    Sorry but the proof that the big antenna's are dependent on the radio as much as it is on the placement of the antenna.
    Generally the 5 foot like a Wilson fgt-5 is a good start, the gain is almost equal to that of a 102" whip. [FONT=Verdana,Arial,Helvetica][FONT=Verdana,Arial,Helvetica][/FONT][/FONT]
