How to determine a U Joint is bad..
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JakeBrakeChampion, Apr 30, 2011.
  1. JakeBrakeChampion
    JakeBrakeChampion Light Load Member
    55
    19
    Apr 14, 2011
    Pennsylvania
    Well I removed what appeared to be worn U joints. When I took the caps off all of the neddle bearings looked clean and well greased.. I run half round yokes all the way back to the rear rear where i have full rounds. The U joint cap appears to be spinning in the half round although i just re tightend the 12 point 1/2 bolts.. Are these considerd bad? Although the needle bearings look good clean and greased?
  3. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    u need to check them while they are installed on the truck. get under the truck and push upward and pull downward on the tailshaft/propshaft, and if you feel any upward or downward movement then the u-joint needs replacing. testing the u-joint off the truck is too hard to check, but the caps should be almost and if not imposible to rotate by hand.
  4. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    you can buy replacment bands with bolts --that will tighten them up--or--you can use some shim stock to lay around the cup then bolt it together--good idea to use removeable lock tite on the bolts---as long as the bearing surface isnt worn--or spalled--you should be ok---i am not a fan of those 1/2 rounds just for that reASON
  5. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    oh i didn't realise he was asking about the bands, untill i read his post again. dop! :biggrin_25523:
  6. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,434
    Dec 31, 2010
    Alberta
    The easiest way to check if a U joint is failing is, after a trip, go under with an infrared heat gun and shoot all of the caps. If one is considerably hotter than the others, it's hooped.
    droy Thanks this.
  7. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Last time I greased mine I did notice some up and down play, but once I pumped It ful of grease it went away. I didn't know if alittle play was normal or not, guess maybe I should get a new u-joint.
    Very good idea! I have actually had the bolts on the cap come loose and the u-joint spun out of the half round while I was driving. Luckily it didn't damage anything beyond the joint.
