How to choose the best portable jump starter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Evae, Sep 14, 2017.
  1. Evae
    Evae Bobtail Member
    Although many people think buying a jump starter isn't a big deal, the reality is quite different. There are some factors you need to pay attention to before buying a portable jump starter so that you can avoid any unpleasant surprises. Buying a portable battery isn't the same as purchasing a bottle of milk; there are a ton of variables and important elements included in the equation. Here are some of the things you should pay attention to before opting for a particular model.
    The power
    The most important thing you need to look for is the sheer power of the unit. Manufacturers usually include "cranking" and "peak" power values.
    Peak amps refer to the highest current value the starter can burst out. For example, a product with 1000 amps of peak power will deliver a thousand amps in the initial burst. However, the value drops significantly with each try. As the current decays with each attempt, it loses consistency and starts using what is known as the cranking power.
    As you might assume, the cranking power refers to the stable current which can be delivered if extended cranking of the engine is required. Therefore, the cranking power is usually the more accurate representative of a particular model's capabilities.
    Safety Protection
    As with any other product, the safety is one of the important factors to look for. However, because you're dealing with electricity, make sure that you opt for the safest model. The things you should pay attention to are:
    • Short circuit protection
    • Over-current protection
    • Overload protection
    • Over-voltage protection
    • Overcharge protection
    As you can see, every feature has an "over" prefix. It means that these units are easy to overuse if they lack protection. However, the products that have these preventive mechanisms can be left unattended without them being dangerous for the environment, and most importantly - your car's battery.
    Auxiliary features
    Many units have some additional features such as an air compressor or a flashlight. If you want a 2-in-1 or even 3-in-1 unit, pay close attention to these additions. People who are often on the road usually need both illumination and an air compressor for deflated tires. You can't expect a professional service out of these additional options, but they are still enough to act as a first aid. Also, if you're looking for multiple charging ports for smart phones, tablets, and more, it's a good idea to check whether the unit you've chosen can charge other devices.
  3. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    A jump pack is almost worthless in a semi. You've got 3 to 4 batteries, each with 900 to 1000 cca. If ONE battery is dead, it'll take a heck of a lot more juice than even the best jump pack can provide. Once, I had 2 pov's hooked up with jumper cables, another 1000 cca marine battery, AND my 30 amp charger, and it STILL was not enough to overcome a single dead battery. 3 more industrial (electric forklift) batteries added to the mix finally got 'er fired up. I would've been better off isolating the dead battery and trying to start the truck on just the other two.
    Buy a good set of jumper cables if you are concerned. That jump pack probably won't be fully charged when you need it, anyway.
    mhyn and driverdriver Thank this.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
  5. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    the op is clearly selling these. but on that note,we bought on of these a few years back,even the cheap off brand one like above,and it does work impressively.
    my wife bought it. i laughed it off as a joke. my mother in laws car had a bad battery and would die off after a day or so,so jump started her car multiple times without recharging with it,and it fits in my hand.
    it says it can start big trucks too. i really really doubt that. but it will start a dead car. ours sat in our car all winter in the case and worked when needed.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    There are jump pack's for trucks. They have 4400 amps available on eBay an amazon. Don't tell me 4400 amps is not enough.
