How to bump a Dock... Jack-knifed?
Discussion in 'Experienced Truckers' Advice' started by Cattleman84, Oct 3, 2018.
  1. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    I need some pointers on how to bump a dock and end up jack-knifed when i finish... Going into a really tight receiver and I'm not sure where to start inorder to end up completely jack-knifed.
    Lepton1 Thanks this.
  3. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,617
    Oct 23, 2009
    Alexandria, AL
    Do you mean like parallel parked with trailer in dock?
  4. Cattleman84
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    I mean trailer is on the dock, and the tractor is at 90 degrees to the trailer.
  5. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    i have only had to end up like that a couple of times myself at an on/off street delivery.
    i had to be somewhat closer to the building nearly at a 90 degree angle, rather than the usual 45?
    then i just backed into the area. if i recall, i may have locked up the trailer brakes with the trolly, to give me a near perfect pivot. then released them to allow the rest of the backing into the spot.
    but been like EON's since i had to do that backing for that delivery, that way.
    Lepton1 and Cattleman84 Thank this.
  6. FozzyNOK
    FozzyNOK Road Train Member
    2,452
    3,774
    Jul 18, 2007
    Oklahomistan
    Its tough and against a wall or old type dock its easier.The problem with attempting this is that you have to be spot on when you get to the dock. As you approach 90 degrees with the tractor, the tail of the trailer is no longer moving backwards... its already moving sideways.
    BUMBACLADWAR, Lepton1 and Cattleman84 Thank this.
  7. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
    Put your wheels all the way back, bump the dock at an angle and push it square with the tractor.
  8. Wargames
    Wargames Captain Crusty
    3,179
    7,336
    Jul 22, 2010
    WI.
    years ago down town Chicago, back down and alley, the dock is flush against the wall. The guy pushes a green dumpster to the back of my truck, throws a sheet of thin metal across. He says, Run it fast, cut across the dumpster, into the building. HELL NO, I says. He says, trust me. 2 construction workers hear this, and make a bet with each other, it will fall in. I say, sign the bill, if it falls, its your problem. It worked. not too keen on me running with a skid across a dumpster.
    magoo68, Lepton1 and Cattleman84 Thank this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Easy in the winter time. Just hit the corner of the dock with the corner of the trailer. Then just keep pushing with the truck and it will pivot in place as the trailer tires slide on the ice and snow.
    Cattleman84 Thanks this.
  10. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,268
    Apr 19, 2018
    I come back at a 45 degree angle and when I get about 2 foot from the dock cut it all the way over hard and usually works for me biggest problem is make sure your tandems are almost where you want them to end up when you cut it ... hard to adjust it seems like I only do it 4 or 5 times a year and i go to a lot of smaller companies never will get good at it
    magoo68 and Cattleman84 Thank this.
  11. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    It's not easy. And a lot of it is just luck and/or trial and error, even for the old hands. The initial angle and point at which you begin your cut must be nearly perfect. Having the tandems back, bumping the dock near the correct spot, then "pushing" until perpendicular with the dock is doable in some situations but it's a good way to tear stuff up on your trailer or their dock.
    Some times, if you can back in as normal, do so, and drop and move out of the way is the easiest solution.
