how to Bid on Loads Using Load Board
Discussion in 'Ask An Owner Operator' started by Assyrian, Jul 6, 2021.
  1. Assyrian
    Assyrian Bobtail Member
    14
    Chicago, IL
    Hi every one !
    I try to search on google but no luck !
    i need name for load board doing bit on load so any one using bit to get load ? if what the name of the load board .
    Thanks
    Reason for edit: how to bit on load using load Board
  3. mnmover
    mnmover Road Train Member
    1,237
    1,103
    Apr 5, 2009
    Lichfield MN
    Truckstop.com is a load board, but you must have current authority to subscribe. CH Robinson, Landstar Broker.com, many load boards are available. BUT you do not want to bid on loads, as usually that ends up with people cutting prices to get the load. You always want to get the broker to add money so the load will get moved.
  4. Assyrian
    14
    Chicago, IL
    mnmover , but a-lot of owner operator doing bid for load so i want to now where they make the bid ! i have new authority ?
  5. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    Sounds like a good one for U-Ship. Keep away from the other load boards.
  6. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    Stay away from bidding, list your truck, let them call you.,
    ProfessionalNoticer Thanks this.
  7. OldeSkool
    OldeSkool Road Train Member
    1,641
    4,424
    Jul 17, 2018
    New Hampshire
    I don’t use the load board personally, but I know guys that do. They email an offer to the broker what they will do it for. You haggle back and forth for a while.
    MTN Boomer Thanks this.
  8. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    Why would you want to bid on anything? There will always be another guy to come in and do it cheaper. How far will you go? Until you can't afford fuel? Or tires? Etc etc. You're better off leasing on somewhere. If you plan to just be the cheapest truck you won't be in business long.
    Speed_Drums and Lite bug Thank this.
  9. OldeSkool
    1,641
    4,424
    Jul 17, 2018
    New Hampshire
    I would imagine he means bidding it higher than they’re asking. Many drivers can get the brokers to go up a bit on a load they need moved.
  10. Assyrian
    14
    Chicago, IL
    YP that what i mean i want know where they bid ?
  11. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    Convoy, coyote, Uber, xpo, JB 360, Schneider and several other cH robinson
    LameMule Thanks this.
